arlo
Urine Test Speeds Detection of Bladder Cancer Recurrence
http://www.medpagetoday.com/HematologyOncology/OtherCancers/dh/2506
**Note that the BladderChek test for the protein NMP22 is an office procedure that yields results within an hour.
**In this study, the test, in combination with cystoscopy, detected 99% of recurrent bladder cancers, significantly better than cystoscopy combined with urine cytology.
Review
HOUSTON, Jan. 18 - A simple urine test, with results available in the office within an hour, can significantly improve and speed the detection of recurrent bladder cancer, investigators here reported.
In a prospective cross-sectional study, the BladderChek test, combined with a cystoscopic examination, detected 99% of all recurrent cancers, according to H. Barton Grossman, M.D., of the M.D. Anderson Cancer Center.
Also, the test alone detected eight of nine cancers that were not found during initial cystoscopy, Dr. Grossman and colleagues reported in the Jan. 18 issue of the Journal of the American Medical Association.
By contrast, the standard urine cytology test, combined with cystoscopy, detected 94.2% of cancers - a rate of detection that was not significantly greater than that of cystoscopy alone, the researchers found.
The BladderChek test, manufactured by Matritech of Newton, Mass., detects elevated amounts of nuclear mitotic apparatus protein, or NMP22, which is released into urine during cell death.
Unlike standard urine cytology, the test for NMP22 does not require whole cancer cells and can be done in a physician's office while the patient waits. It is also cheaper than cytology, the researchers noted.
Bladder cancer is the fifth most common malignancy in the U.S., and between 50% and 90% of patients will suffer a recurrence. "A test like the NMP22 assay, which is accurate and easy to administer, I believe will help identify and treat patients earlier when they have better chance for a good outcome," Dr. Grossman said.
Between September, 2001 and February, 2002, researchers at 23 academic, private practice, and hospital facilities in nine states prospectively enrolled 668 consecutive patients with a history of bladder cancer.
Patients provided a voided urine sample for analysis of NMP22 protein and cytology before they underwent cystoscopy.
The study found:
Recurrent bladder cancer was found in 103 patients.
Cystoscopy alone detected 94 of the recurrences, or 91.3%
The NMP22 assay detected eight of the nine missed cancers, but had an overall sensitivity of 49.5%, detecting 51 of the 103 cancers.
Urine cytology detected three of the nine missed cancers, but had an overall sensitivity of 12.2%, detecting 12 of the 98 cancers in patients for which cytology was available.
The additional sensitivity with the combination of the NMP22 test and cystoscopy is "good news for patients," said urologist Barry Stein, M.D., of Brown Medical School, a co-author of the study.
"If you have been treated for bladder cancer and are being monitored for recurrence, the accuracy of your diagnosis is extremely important," Dr. Stein said. "If we say there's no recurrence of cancer, we want to be right."
For clinicians, the advantage of the test is that is gives a quick check on the validity of results from cystoscopy, he said. "You know the answer before the patient is out of your office," he said. "If the result is positive, and you didn't see anything from the cystoscopy, you would check to see if you missed something."
The NMP22 test had a specificity of 87.3%, meaning that false-positive results occurred 13% of the time. These false-positive results could lead to further diagnostic testing in patients without recurrent bladder cancer, the researchers noted. That didn't happen in this study, because all patients had a cystoscopy.
Also, the researchers noted, it is possible that some of the false-positives were in fact recurrent cancer that was not detected by cystoscopy; lack of follow-up data means recurrence can't be ruled out.
Primary source: Journal of the American Medical Association
Source reference:
Grossman HB et al. Surveillance for Recurrent Bladder Cancer Using a Point-of-Care Proteomic Assay. JAMA. 2006;295:299-305.
