sd-slider
*nix Guru's Unite - Shell Script advice/help
I am trying to clean up multiple syslog digests to make reporting a breeze for my Mgmnt(arrgh!)>:(
I basically have a date stamped syslog entry of:
Jan 18 13:18:07 10.3.1.99 Elbie, Interface ethernet2, state up
The system name varies so there will be multiple if/then/while statements to filter the grep’d output to the appropriate files/variables.
My dilemma……I would like to look @ each days date from the date command as follows and force the numeric value on the previous day into a variable and print that variable elsewhere in the script. The problem is n-1 is zero on the first of every month…… Date output:
Thu Jan 18 14:43:44 PST 2006
My current script is forcing the current date into $PREVDAY at the end of the script and grep’n the desired values for the current days report (confused?).
Anyhoo, the script is as follows:
[root@otter scripts]# vi maildev
#!/bin/bash
### Get some info
cat /var/log/messages | grep Elbie > /home/scripts/lbsum.txt
### SET THE VARIABLES
day=`echo $PREVDAY | awk '{print $3}'`
month=`echo $PREVDAY | awk '{print $2}'`
year=`echo $PREVDAY | awk '{print $6}'`
test=`cat /home/scripts/lbsum.txt | grep "$month $day"`
### Set the environment for the next days reporting cycle
PREVDAY=`date`
### SEND THE COMPLETED MAIL
Mail -s "Dev Awk Script Output for $month $day $year" user@dot.com <$test
EOF
Any suggestions or shortcuts would be appreciated. I was hoping to have a more “portable” solution that didn’t require volatile variables or static files for storing info.
Thanks,
=Slider
Anvil Brother #69
Sidelined with a 5mm C5-C6 herniated disk...
Back2Back slammers and 40yr old fat guys don't mix!
I thougth my method was simpler than how you're setting it up.
Like this:
day=`date +%a --date="yesterday"`
month=`date +%b --date="yesterday"`
Or you could pull in the full date string as above and use awk for the fields, really depends on your concept of simple I guess :)
Hope that helped!
TV's got them images, TV's got them all, nothing's shocking.
If you already know awk, the systime() and strftime() functions of gawk--not regular awk-- also come in handy.
eg
gawk 'BEGIN {print strftime ("%c", systime() - 86400)}'
or in perl,
perl -e 'use POSIX;print strftime("%c", localtime(time - 86400));'
86400 being the number of seconds in 1 day.
My advice is to do what your parents did; get a job, sir. The bums will always lose. Do you hear me, Lebowski?
