Casch 0 #1 February 6, 2006 Believe it or not, I'm doing this crap for fun. I'm trying to teach myself how to solve complex rational expressions. Can anyone tell me if this is simplified as much as possible? 1 - 1 x + h x -h = h hx^2 + xh^2 Quote Share this post Link to post Share on other sites
faulknerwn 38 #2 February 6, 2006 Hmmm. I simplified it (if my math is right) to hx=0 Quote Share this post Link to post Share on other sites
wlie 0 #3 February 6, 2006 According to my TI-89 the correct answer is 1/h(x+h) - 1/hxMy other ride is the relative wind. Quote Share this post Link to post Share on other sites
Casch 0 #4 February 6, 2006 That would require either x or h to be zero, and neither can be zero without causing a divide by zero error in the original expression. Right? Heh, I haven't done any substancial math work since pre-calculus in high school Quote Share this post Link to post Share on other sites
deea 0 #5 February 6, 2006 here, I did it out for you (hope I understood correctly what you were asking for). andreea Quote Share this post Link to post Share on other sites
faulknerwn 38 #6 February 6, 2006 Hmmm. Ah - I dropped a negative sign. Let's see 1. -h^2= (1/(x+h)-1/x)(hx^2+xh^2) 2. h^2=( (x- (x+h))/(x^2+hx)) (hx^2+xh^2) 3. (-h^2)(x^2+hx) = (-h) (hx^2+xh^2) 4. -h^2x^2 -h^3x = -hx^2+xh^2 5. 0=xh^2-hx^2-h^2x-h^3x 6. (hx) (h-x-hx-h^2) = 0 Since as someone pointed out hx cannot equal 0 h=h^2+hx+x That's as far as I get Quote Share this post Link to post Share on other sites
labrys 0 #7 February 6, 2006 you have an extra "h" to factor out: -1 / x(x+h) edit typoOwned by Remi #? Quote Share this post Link to post Share on other sites
deea 0 #8 February 6, 2006 wait a sec... could you clarify your question a little bit? The other posts are confusing me :) Are you asking if the left hand side, when simplified, results in the RHS or something simpler, or are you giving this whole thing as an equation to be solved (if so, in which variable?) My previous post refers to option #1. Quote Share this post Link to post Share on other sites
labrys 0 #9 February 6, 2006 I took it the same way you did. The LHS is the complex expression and the RHS is his answer.Owned by Remi #? Quote Share this post Link to post Share on other sites
Casch 0 #10 February 6, 2006 Sorry about the confusion, and thank you for your answer :) That was EXACTLY what I was looking for. Thank you so much for the help Quote Share this post Link to post Share on other sites
kallend 2,196 #11 February 6, 2006 QuoteAccording to my TI-89 the correct answer is 1/h(x+h) - 1/hx Speaking here as a professor, I don't think the point of the exercise is to see if your TI can do it.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
