woodpecker 0 #1 February 10, 2008 Which would be a better material for a freefly suit?SONIC WOODY #146 There is a fine line between cockiness and confidence -- which side of the line are you on? Quote Share this post Link to post Share on other sites
darkwing 5 #2 February 10, 2008 It depends (pretty much always the answer). Bull denim IS cotton. For any jumpsuit you address how much body the fabric needs to have. If you want lots of drag, you often use a heavier bodied fabric. From a durability perspective, I'd usually prefer a poly-cotton blend anyway. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
woodpecker 0 #3 February 10, 2008 poly-cotton it is. Thanks for the help.SONIC WOODY #146 There is a fine line between cockiness and confidence -- which side of the line are you on? Quote Share this post Link to post Share on other sites
diablopilot 2 #4 February 10, 2008 QuoteIt depends (pretty much always the answer). Bull denim IS cotton. For any jumpsuit you address how much body the fabric needs to have. If you want lots of drag, you often use a heavier bodied fabric. From a durability perspective, I'd usually prefer a poly-cotton blend anyway. Just as an add on statement, heavier can be good for reduced fall rate, but only if it's got a "soft hand". Too stiff of a fabric end's up being faster than a couple layers of a lighter soft fabric.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
