micro
wingtip vortices
um... that's not the wingtips. :P
I'm not talking about the vortices coming off the flaps, you doofus. I'm talking about those great big curly cue clouds that were formed by the... say it with me now....
I miss Lee.
And JP.
And Chris. And...
Oh, Those vorticies... :$ oops... sorry... :$
Livin' on the Edge... sleeping with my rigger's wife...
...moisture in the atmosphere?
a prereq perhaps... but....
I miss Lee.
And JP.
And Chris. And...
that's ok, silly. :)
I miss Lee.
And JP.
And Chris. And...
In ATC we call it "wake turbulence". Depending on the weight/size of the aircraft we have to apply different separation standards between heavy, large and small aircraft and issue cautionary advisories i.e "Caution wake turbulence, departing B757".
A Cessna 182 behind a Boeing 757 or a Heavy Boeing 747 or an Airbus can get flipped over very easily and it ain't pretty to watch.
"I'm not a gynecologist but I will take a look at it"
RB #1295, Smokey Sister #1, HellFish #658, Dirty Sanchez #194, Muff Brothers #3834, POPS #9614, Orfun Foster-Parent?"
http://www.airliners.net/open.file/0892875/L/
They get bigger when the plane does.
Actually, slow and clean (no flaps) creates the strongest vortices.
I love those pics....
I once saw a video of military tests on wingtip vortices where smoke-dyes were set off on the ground... a huge C-5 would fly over at various altitudes and they would measure the sizes of the vortices... just incredible... as you mentioned, you can clearly see in the video that when the C-5 goes by slow and w/ no flaps, the vortices are just frightening.
Also, in other test videos, a lear jet would fly in the visible wing-tip vortices of a larger jet (kc-135 maybe, i don't recall)... in the video, you can see when the lear enters the vortice, it just gets flipped and tumbled like a little toy. Man!
I miss Lee.
And JP.
And Chris. And...
I hear that the 757 wake turb is particularly nasty.
Yeah when it came out it was under 300,000 lbs so it categorized as a large like the Boeing 727 or a MD88 which is was going to replace.
To be listed as a heavy (B747) aircraft must be capable of 300,000 lbs so more it didn't fit the criteria and a lot of airports where the B757 was intended to be used do not allow heavy aircraft to operate on a routine basis. So Boeing did not want it listed as a heavy because it would stand to lose a lot of orders from the airlines.
Well the wake turbulence it created was as bad as a heavy so they created a separate standard for the B757 so it is still listed as a large but with it's own set of rules.
