mangledspoon 0 #1 January 14, 2008 Is there a way of converting the 2-pin vigil to a one pin? Or alternatively, can you just use a 2-pin vigil in a 1-pin container? I want to buy a new rig and was hoping to save the cost of having to get a new vigil. Quote Share this post Link to post Share on other sites
monkycndo 0 #2 January 14, 2008 You can use a two pin cutter assembly on a one pin container.50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
LouDiamond 1 #3 January 14, 2008 Yes, page 31 of your owners manual talks about replacing the cutter(pictures included). You(your rigger) can replace the 2 pin cutter assembly with a 1 pin cutter assembly."It's just skydiving..additional drama is not required" Some people dream about flying, I live my dream SKYMONKEY PUBLISHING Quote Share this post Link to post Share on other sites
Liemberg 0 #4 January 14, 2008 Quote Is there a way of converting the 2-pin vigil to a one pin? Owner of several 2 pin rigs innocently asks: *How much for that 'used'cutter?* (i.e. Yes , you can swap Vigil cutters easily. AND the two pin originally costs twice as much as the one pin...) "Whoever in discussion adduces authority uses not intellect but memory." - Leonardo da Vinci A thousand words... Quote Share this post Link to post Share on other sites
riggerrob 643 #5 January 15, 2008 ... not quite sure what the Vigil manual says ... but the Cypres manuals says that you can install a two-pin Cypres in a one-pin container, just coil the extra cutter and cable neatly in the pocket. Quote Share this post Link to post Share on other sites
