hooked 0 #1 March 12, 2006 If someone recorded onto a dvd+R........can you make a copy of it to a dvd-R? -------------------------------------- Sometimes we're just being Humans.....But we're always Human Beings. Quote Share this post Link to post Share on other sites
yamtx73 0 #2 March 12, 2006 QuoteIf someone recorded onto a dvd+R........can you make a copy of it to a dvd-R? Sure, why not? I've copied a number of dvd's that were burned in other formats and never had any problems.The only naturals in this sport shit thru feathers... Quote Share this post Link to post Share on other sites
hooked 0 #3 March 12, 2006 Thanks. I didn't know....that's why I asked....before trying it. I thought it might be a stupid question -------------------------------------- Sometimes we're just being Humans.....But we're always Human Beings. Quote Share this post Link to post Share on other sites
BirdWoman 0 #4 March 12, 2006 Yes, you should be able to, as long as the DVD burner you are using uses DVD-R discs. Otherwise, you should be able to burn any DVD."I don't know where it is that I'm going, but wherever it is there I'll be!" --quoted by me Quote Share this post Link to post Share on other sites
dqpacker 7 #5 March 12, 2006 On some laptop cpu. you can only burn one of the two. Quote Share this post Link to post Share on other sites
billvon 3,109 #6 March 12, 2006 Yes. The writer has to support DVD-R. Most drives will read both formats. If you are using a single drive, then it has to support both formats. Quote Share this post Link to post Share on other sites
yamtx73 0 #7 March 12, 2006 Most current dvd burners support both DVD+R and DVD-R, if it's an older unit you'll have to check to see if it supports both. Both of my dvd burners support both +R and -R (as well as NTSC and PAL formats), both were purchased within the last 4 years.The only naturals in this sport shit thru feathers... Quote Share this post Link to post Share on other sites
hooked 0 #8 March 12, 2006 So....what's the pros/cons over + or -? I thought more dvd players recognized the - format rather than +. I've always used the - for dvds, but have received a dvd recorded in + and it doesn't work in one of my dvd players. So I thought if I copied it to a -dvd I could play it in more players. -------------------------------------- Sometimes we're just being Humans.....But we're always Human Beings. Quote Share this post Link to post Share on other sites
Chizazz 0 #9 March 12, 2006 I noticed that dvd -R's don't work in older dvd players. Quote Share this post Link to post Share on other sites
pincheck 0 #10 March 12, 2006 if you have problems with one type of disc check the manufacters website to see if there are any updates for flashing the players firmware, it may be a known problem. Billy-Sonic Haggis Flickr-Fun Quote Share this post Link to post Share on other sites
yamtx73 0 #11 March 12, 2006 When the DVD burner first came out the manufacturers couldn't decide on any one format, some preferred the -R while others preferred the +R. Panasonic, Toshiba, Apple Computer, Hitachi, NEC, Pioneer, Samsung and Sharp all supported the -R format. Philips, Sony, Hewlett-Packard, Dell, Ricoh, Yamaha and others supported the +R format. Both claim to have certain benefits the other doesn't (what those benefits are I don't know), most newer dvd burners now support both formats and will continue to do so until the industry finally decides on one format. The reason the -R may not have worked in your older dvd player may not have anything to do with it being +R or -R it could be that the dvd is PAL format instead of NTSC (or vice versa). PAL discs won't work in an NTSC player and NTSC won't play in a PAL player. Check the format of the disc, that could be the issue, most newer dvd burners (and software) can read/write in both formats. PAL is used mostly in Europe, NTSC is used mostly in North America however you'll find some exceptions.The only naturals in this sport shit thru feathers... Quote Share this post Link to post Share on other sites
hooked 0 #12 March 12, 2006 Wow, you all have been so helpful. It's actually the + that wouldn't play, but I've played other + dvd's in the player without any problems. I'm beginning to think that it wasn't recorded correctly or it wasn't finalized or something. It plays on my computer but had a few 'glitches' playing it. I'm going to check with the person that copied it to dvd originally. -------------------------------------- Sometimes we're just being Humans.....But we're always Human Beings. Quote Share this post Link to post Share on other sites
yamtx73 0 #13 March 12, 2006 If other +R's have played in the player before then it's likely the dvd is in the PAL or NTSC format. My dvd player is NTSC, if I burn a dvd in PAL it won't play in the dvd player. Since it works in your dvd burner I'd try burning it again and changing formats.The only naturals in this sport shit thru feathers... Quote Share this post Link to post Share on other sites
hooked 0 #14 March 12, 2006 Thanks, I'll copy it to - and see if that works any better. -------------------------------------- Sometimes we're just being Humans.....But we're always Human Beings. Quote Share this post Link to post Share on other sites
