lawrocket
A little help with Internet Explorer, please...
For some reason, when I open up new windows, they are about 1/8 the size of the full screen. This embitters me because the mark I want to go to gets lost when I expand it, and I have to scroll up and down.
How do I get the window to open to a full screen size?
My wife is hotter than your wife.
Use Firefox.
I am trying out Opera 9.0.b. It's pretty impressive so far, with a pretty good UI, and WAY faster than Firefox, IE or Safari.
Baby steps... he's still using IE by choice. I only use it for stuff that doesn't render well in Firefox (like Outlook webmail). :D
Right-click the IE shortcut you use to open IE (or create a new shortcut), open the "Shortcut" tab, expand the "Run" listbox, and select "Maximized".
Edited to add: You can also press F11 anytime to toggle full screen mode quickly.
From http://www.mvps.org/winhelp2002/ietips.htm:
Ever notice sometimes you right-click on a link and open a new window and it's not full screen? This usually occurs because IE remembers the last window size when closed. Many times a background pop-up will do this too, if it is the last window closed. To resize the window and regain control:
Close all instances of Internet Explorer except for one.
Right-click on a link in the page and select: "Open in New Window"
Close the first browser window using the [ X ] (upper right corner)
Resize the window manually by dragging the sides to the desired size.
Note: Do NOT click the Maximize button, you must do it manually.
Hold down the Ctrl key and click the Close button (upper right)
[Exception]
In some cases the "Remember last window size" info becomes corrupted in the Registry.
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
"Window_Placement"=
To reset the "Window_Placement" entry to default. You can download a small reg file to reset (to default) and correct this behavior.
Download: ResetWindowPlacement.reg [right-click and select: "Save Target As"]
To use: right-click and select: Merge - Ok the prompt and reboot.
Walt
See now that taught me something new. I was gonna explain how that tiny window came from a popup (porn, most likely) and IE remembered it and how to get it to remember a new size. Then I was gonna yell STOP LOOKIN' AT PORN!"
~ Lisa
~ Do you Rigminder?
Use Firefox.
I used firefox for a while. There's just too much that doesn't work well with it, and it's way too high maintenance. Since service pack two, I've been pretty happy with IE.
Seriously, W.T.F. mate?
