tdog 0 #1 November 8, 2007 What are the different materials that are used as tucktab and flap stiffener inserts? Where can you get these materials? Recommendations for cutting these materials, both for inserting grommets and cutting to size so edges are smooth and not razor like? Note - in the learning project I am currently playing with, there are no TSO/Manufacture Recommendation concerns I must follow, so throw out any and all materials you have seen used, along with the pros and cons with each. Quote Share this post Link to post Share on other sites
peek 21 #2 November 8, 2007 QuoteRecommendations for cutting these materials, both for inserting grommets and cutting to size so edges are smooth and not razor like? I have always used tin snips.... (though I must admit I have always had tin snips around.) Large scissors might work for some of the softer materials. ...and then treated the edges with sandpaper. Quote Share this post Link to post Share on other sites
riggermick 7 #3 November 8, 2007 Cadillac plastics N Hollywood, CA. 818 980 0840. Most rigs use two different thicknesses of MDS nylon. 1/16 for heavy duty applications such as main container side flaps and 1/32 for lighter applications such as riser cover pockets etc. Cadillac's stock #'s are 174020 for 1/16 and 298544 for 1/32. Scissors work well for most work. Heat the stiffeners with a hair dryer and they will be eaiser to cut/ punch/ sew. Hope this helps. Mick. Quote Share this post Link to post Share on other sites
councilman24 37 #4 November 9, 2007 Do a search. There was a recent significant thread.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
Slurp56 0 #5 November 9, 2007 Typically you want to use Nylon 6 MDS. Avoid the Nylon 6/6, it is brittle and will likely break on you during product manufacture. Riggermick provided a good source for the material. You may also be able to buy some from paragear, rig manufacturers, or McMaster-Carr. You can use heavy duty scissors, edge sharpness shouldnt be a problem, but you could probably rake the material over a straight edge to knock down an sharp spots. For the corners, just round them using the scissors. To cut the material for grommets use a punch, it works really well.________________________________________ I have proof-read this post 500 times, but I guarantee you'll still manage to find a flaw. Quote Share this post Link to post Share on other sites
riggerrob 643 #6 November 11, 2007 White, molded sheet nylatron was fashionable a decade or so ago. Now the current fashion is molybdnum disulfide reinforced nylon. It is grey. 20/1000 for tuck tabs 30/1000 of pin covers 40/1000 for side flaps and grommet reinforcement Quote Share this post Link to post Share on other sites
