Dumpster
I'm buying a house!
Closing on the 28th of the month. Modest little 2 bed 1 bath with a good sized yard and 2-car garage - Needs a little work but not that bad. 45 minutes from Sky Knights, 1-1/2 from CSC and 2 hours from SDC. Ten minutes from work.
(Incidentally, the divorce is final on the 1st of May.)
Easy Does It
Hey what is that white stuff in the picture?? :S:D
Hate to hear of turmoil. (Divorce)
Congrats on the place though.
Laters,
K-MAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! B|
The REAL KRAAAAAAAAAAAAAAAAAMER!
"HESITATION CAUSES DEATH!!!"
"Be Slow to Fall into Friendship; but when Thou Art in, Continue Firm & Constant." - SOCRATES
The pic is a little old - I'll get some more inside -n- outside pics later - Got a bunch of plans for it (over the next 5 years-) to include:
"Dumpsters' Semi-Extreme (sort-of) Home Makeover, Skydiver Edition"
(not neccessarily in order-)
Upgrade electrical to 200 amp service
Update plumbing
Update bath - (Floor needs work-)
Update kitchen
Install central air
Fence
New garage
Motorcycle to park in the garage
New front porch
New Deck
4-6 person spa on the deck.
Some one warm-n-cuddly to share the master bedroom with me -
I'm really happy to be able to buy something like this 100% on my own though!
Easy Does It
that really must be a great feeling. we just bought a house six months ago. i love looking at it as i drive home from work. doing it on your own should make it even more special to you.
blue stuff,
p.j.
pulling is cool. keep it in the skin
t
Another good feeling is that my payments will be over $300 less than what I was paying on the first house, and I'll be able to preserve a bit of the capital from the sale, to be used for improvement. And to spoil myself just a little, after all, I did just go through a divorce!
Yes, it feels good! I'm doing OK!
Easy Does It
There's always something to do on a house. Even after you get everything up to 100% there is still maintenance to do.
Then you sit back and look at a room and get a wild hair and decide to paint - Paint leads to carpet, which leads to new trim, and of course new window treatments and light fixtures. Now that the one room looks great the others look terrible and the whole cycle starts all over. I should buy stock in Home Depot and Ace Hardware.
Easy Does It
Update plumbing
Update kitchen
Install central air
Fence
New garage
New front porch
New Deck
I see you forgot to list all the copper you will need to pull, cat 5, speaker, coax for your TV, but most of all, pull lot's of cat 5. I do like wired rather than wireless...
OK, I am a geek, and actually AC might happen before the cat 5, or maybe at the same time.
Congratulations!
Johnsisland
Arch? I can arch just fine with my back to the ground.
The "upgrade electrical" includes pulling lots of copper and installing alot of new outlets and stuff - This place was built in the 50's and still has screw-in fuses. The fuse box will be replaced with a healthy 200 amp breaker panel, (Square D of course-) 100 amps for the house and another 100 amps going to a sub-panel out in the garage. (It would be really sweet if I could get three-phase power, but I don't think I can in a residential neighborhood.)
Never thought about pulling Cat 5 but I may as well as long as I'll be up in the attic and down in the crawl doing all the other work.
I'm getting an estimate for a 24x30 garage with an 8x16 door.
The plumbing is going to be the real challenge - The whole house is done in iron on the supply side as well as waste. I'll probably leave the waste side intact and replace the supply side with copper. The tiny bathroom needs to be gutted and reworked from the studs out. Adding a bath to the master bedroom would be nice but quite expensive, I don't know that it would add enough to the value of the house to get my money out of it.
Whew!!
Easy Does It
Yes, 90% financed - The odd 10% I have financed I may be able to pay back within a few years, dropping the monthly to less than $900.00. My goal is to have as little financed as possible, which means a lower monthly payment and building equity that much more quickly. I'll probably sell ain about 5 to 7 years, and should turn a pretty nice profit in this area.
Easy Does It
Bump -
Finally got into the "new" house!!!!
(The closing was a complete fiasco, and took four days thanks to a lawyer that didn't do her job - But that could be a whole other thread.)
Pulled up all the stinking carpet in the place to expose an oak floor. First room to get worked over will be my bedroom. I'll be replacing the outlets in the room and taking out the old trim, then painting, then refinishing the floor, then new doors and new trim go up. Not sure if the living room or my son's bedroom will be next.
I'll be starting the electrical upgrade soon, too.
This house will be on the two-year plan. When it's done, I'll be selling it.
Easy Does It
