millertime24 8 #1 October 22, 2007 If you turn the adjustment wheel on the side of an alti-2 galaxy all the way around 360deg will it completely screw up the reading on the way up to altitude?Muff #5048 Quote Share this post Link to post Share on other sites
pilotdave 0 #2 October 22, 2007 Nope. Won't do any harm. It'll work normally. Dave Quote Share this post Link to post Share on other sites
indyz 1 #3 October 22, 2007 The secret of skydiving altimeter adjustments is that you aren't really calibrating the altimeter, you are just rotating the entire internal assembly. You can see this for yourself by taking the back cover off an Altimaster Galaxy or similar alti. Think of it as setting the time on the clock by spinning the face instead of moving the hands. Quote Share this post Link to post Share on other sites
millertime24 8 #4 October 22, 2007 I really wanted to do that but alti-2 says it voids the warranty if anyone but them does it. I just bought it. dont remember if i mentioned that or not.Muff #5048 Quote Share this post Link to post Share on other sites
indyz 1 #5 October 22, 2007 QuoteI really wanted to do that but alti-2 says it voids the warranty if anyone but them does it. I just bought it. dont remember if i mentioned that or not. How would they ever know? The screws you remove to replace the wrist strap are the same screws that hold the case together. Quote Share this post Link to post Share on other sites
FLJB 0 #6 October 23, 2007 I had the same question. Check the Galaxy online manual for detailed explanation of technical info. Below is a link to the FAQ page. http://www.alti-2.com/customer%20support/faq.htm.[url] Quote Share this post Link to post Share on other sites
IanHarrop 42 #7 October 23, 2007 QuoteI had the same question. Check the Galaxy online manual for detailed explanation of technical info. Below is a link to the FAQ page. http://www.alti-2.com/customer%20support/faq.htm. Clicky [url]http://www.alti-2.com/customer%20support/faq.htm"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
