hackish 8
If you’re ever in Deland, stop in and see me. I will take to into the shop and show you how you can do that yourself.
Maybe next winter I will be going down to Deland so if I do then I'll definitely have to look you up. Being new to this sport I don't really know anything about mirage.
I can appreciate how much nicer the PD280 flies when compared to the Parafab 284 in the pile of student rigs so I can see why the secrets held in parachute patterns are not exactly that "available".
-Michael
QuoteI can see why the secrets held in parachute patterns are not exactly that "available".
For a dollar 95 @ Jo Ann's fabrics you can get you a seam ripper and learn to use it, there is your "pattern maker" you can pick the stiches of any canpoy you want a pattern for and there you go instance pattern.
skybytch 273
QuoteFor a dollar 95 @ Jo Ann's fabrics you can get you a seam ripper and learn to use it, there is your "pattern maker" you can pick the stiches of any canpoy you want a pattern for and there you go instance pattern
Don't forget to add some seam allowance.
Good point.
riggerrob 643
Then I bought a kit for a 220 square foot, 9-cell from Para-Kit and made 350 jumps on it before ZP fabric came into fashion. Both canopies are still stored in my attic.
riggerrob 643
Reserve pilot chute patterns are a bit more difficult because of springs, aluminum caps etc. The most complicated reserve pilot chute is found on a Vector with six curved panels, a padded cap, and aluminum cap, a spring, etc.
Tandem drogues are so complicated that I have never seen a home-made drogue. Maybe it has to do with the various bridle configurations or the threat of nasty lawsuit if anyone gets hurt while using non-compatible, non-TSOed components.
mark 107
QuoteQuoteFor a dollar 95 @ Jo Ann's fabrics you can get you a seam ripper and learn to use it, there is your "pattern maker" you can pick the stitches of any canopy you want a pattern for and there you go -- instant pattern
Don't forget to add some seam allowance.![]()
Uh, are canopies cut and sewn together without a seam allowance these days?
Mark
MrBrant 0
QuoteQuoteQuoteFor a dollar 95 @ Jo Ann's fabrics you can get you a seam ripper and learn to use it, there is your "pattern maker" you can pick the stitches of any canopy you want a pattern for and there you go -- instant pattern
Mark
I think what was meant is that if you scale down a canopy, it will shrink the seam allowances. These will have to be re-increased since you'll still need the same allowance for your seams, whether the canopy itself is smaller or not.
JerryBaumchen 1,467
QuoteTandem drogues are so complicated that I have never seen a home-made drogue.
Actually, Jamie Woodward's wife ( a Master Rigger ) made a lot of drogues for his Strong tandem rigs. He actually got some form of 'FAA-approval' to build them.
Strong fought it vigorously but in the end Jamie built his own.
JerryBaumchen
riggerrob 643
Hee!
Jerry,
We did not talk about that - very loudly - around Snohomish.
when Ted Strong came to visit - far an accuracy competition - we quietly shoved all those "suspect" rigs in the back room.
Hee!
Hee!
I could do that, but I will have to give this some considerable thought first. Um, um, NO.
Jeff
Come on, I have a nice Singer 31-15 with a folder that I got from ParaGear & I do really nice work
