Jeffrey 1
Eric Fradet patented a system for Main Assisted Reserve Deployments (MARD) sometime between1993 and 02.
In 1998, the French company producing and selling the ADVANCE harness/container with Eric’s MARD system was Parafun. But that company is now under new ownership and is called Basik Air Concept.
Patrick Deayardon had a prototype of the early Eric Fradet MARD system and I adapted one to his Vector 3 prototype back in 94 or 95. I’m not sure if he ever used it.
This French Parafun system was shown to the U.S. public during the 1999 San Diego PIA Symposium. I believe Mike Truffer wrote an article in skydiving about it.
And by the way, the SkyHook is only one of many ways to cleanly accomplish a Main Assisted Reserve Deployment.
Jeff
Jeff
kallend 2,230
QuoteOur local master rigger recently opened up someone's reserve and found clamps STILL ATTACHED to the canopy
Learn about your gear, people... in the end, you're responsible for saving your own ass, and the fact that it's someone else's fault and/or you didn't know any better isn't much consolation if you're dead.
How will learning about my gear help me diagnose a clamped reserve hiding behind a rigger's seal?
jumper03 0
QuoteQuotef you have full confodence in your "curved" reserve pin to pull from odd angles, as unlikely as that senaireo my be, why did you feel the need to introduce your new and improved BIGFATSQUAREPOSPEGPENTHATEVERYONEHATESBECOUSETHEYCAN'TSHUVEITTHROUGHATIGHTLOOPTOSAVETHERELIVES.
Because Sigma Reserve pins were regularly being bent in the field, by riggers closing containers too tight.
riggerlee took the words right out of my mouth.
And if you bend that pin now, you've done some work!!
Scars remind us that the past is real
The problem with making a point on those pins is that they are not "machined" but stamp cut and then tumble polished.
sundevil777 102
QuoteThe problem with making a point on those pins is that they are not "machined" but stamp cut and then tumble polished.
That doesn't explain why it can't have more of a point. It would just be a little more expensive to provide a process after the stamping to get a bit of a point.
People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am
It would add a machining step adding significant cost. I haven't found any real need for a more "pointy" pin.
