JWB 0 #1 July 29, 2007 Maybe one of you out there can help me find instructions on how to build a Cypress closing loop for a Tear Drop rig. I have down loaded and read the owners manual, nothing about how to build it there. Any advice would be well appreaciated. Thanks JWB Quote Share this post Link to post Share on other sites
pchapman 280 #2 July 29, 2007 I never found out the factory way either; they aren't always very responsive to questions. One thing I've done is just to use the same principles as building a loop for a Reflex. (That's not in the manual either but there does exist a printed sheet showing construction details. Not sure offhand if it is on parachutemanuals.com.) I also have notes from a dz.com post by someone who had contacted TSE about the Teardrop. The loop was to be built 2" from washer to finger trap, with a 1.5" long fingertrapped section. (I haven't checked the numbers out, but 1.5" is the same as used on the Reflex.) Better answers welcome. Quote Share this post Link to post Share on other sites
elduderino 0 #3 July 29, 2007 airtec /SSK has maybe something in their manual or you order the loops directly there...then you can rebuild them.... Quote Share this post Link to post Share on other sites
AirtecKai 0 #4 July 30, 2007 Hi there, As this question was asked a few times in the past, we made a short "Tear Drop closing loop info" today. Please have a look at the attachment. Best regards, Kai *Edit moaned about some spelling* Quote Share this post Link to post Share on other sites
AirtecKai 0 #5 July 30, 2007 Here is a link to download a higher quality pdf: www.cypres.cc/ftp_downloads/info/TearDropLoop.pdf Blue Skies, Kai Quote Share this post Link to post Share on other sites
elduderino 0 #6 July 31, 2007 yepp,...i told you Quote Share this post Link to post Share on other sites
JWB 0 #7 August 4, 2007 Yes you did, and thank you for the help. The factory told me to build it like the one that was in it. Problem is, the one that is in it doesn't look right. It might be, but I need proof! Quote Share this post Link to post Share on other sites
bobjohns1 0 #8 August 5, 2007 I suggest making a normal non-adjustable fixed length loop Also adding a aluminum (1"x2") cover held in place by gaffer tape to protect the exposed loop I had a reserve ride at 16000' on exit when the door frame hit the "exposed" single strength loop area causing it to break My team leader told me to make it not happen again[email]Quote Quote Share this post Link to post Share on other sites JWB 0 #9 August 6, 2007 A single length non-adjustable normal loop? Maybe that could be done with a lot of experimenting. I got a detailed instruction sheet from AirtecKai and that worked. Thanks. How did the door frame hit the exposed part if it was in the channel? Just an unlucky good shot? Did you find someone to do CReW with? Ha-Ha. Quote Share this post Link to post Share on other sites mrobiette 0 #10 August 6, 2007 QuoteHow did the door frame hit the exposed part if it was in the channel? Just an unlucky good shot? There have been at least 2 incidents over the last few years here in the UK that I know of where someone has caught their Teardrop poptop on the door on exit. One broke the loop and resulted in a reserve ride from 13K, the other didn't deploy the reserve but subsequent examination on the ground revealed the impact had bent the reserve pin. Quote Share this post Link to post Share on other sites riggerrob 644 #11 August 7, 2007 That merely proves the theory that if you slam any rig long enough and hard enough against any door frame, you will eventually break the loop. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
