steve1 5
true, there may have been some 100-way jumpers out in the dirt, but really the pertinent area for this incident is the grass landing area at Perris and the rules pertaining to it.
The only other thing i might add is the jumper who landed north landed about a second after another jumper landing to the south, though that south-landing jumper was actually pretty close to the west side of the grass, and there was PLENTY of room for the other guy to land.
Either way, the moral of the story is, at Perris if you are in the air and you see two jumpers landing opposite directions on the grass, then the grass is CLOSED and you land out.
As for the jumper that was hit...he was NOT on the 100-ways, he was on the fun-jump load.
bigbearfng 18
First one on the grass entered mid field-I admit it actually looked like he was going to land south to north at first to me also.
Lesson-set up in an obvious (especially obvious for newbs) manner.
Winds had been light and variable with flags shifting-but typical Perris it can change as your already on approach-I'll take the down winder if need be.
After the first one (on grass) landed to the south I was already setting up approach-looked behind me and saw the newbs set up to land south to north-yes I could of also landed to south, but I also don't expect/want to see a newb attempt a low turn and get hurt.
If I did land to south at that point I saw myself as the one likely getting hit.....
I saw the way clear to the North and went long and landed off the grass to the North wanting to avoid what looked likely......
Absolutely newb with target fixation after talking to him later.
And yes when you're on the ground heads up-which I admit I've been guilty of a lack of also-who hasn't if you're being honest? Don't get complacent!
I like to be my own harshest critic-feel free to join me! I never want to stop learning.
QuoteHmm, since I was one of the obstacles and was not anywhere near the flag line but was still walking through the dirt
Well then I stand corrected, but if you were still on the dirt south of the grass, then you were likely outside of my field of view and hardly an obstacle for this particular landing approach. I was almost directly opposite where and when it happened. There was nobody else that I saw on the grass south of the collision except those of us walking along the flag line on the opposite side of the grass.
Target fixation may well have played a part. As I said, there were several likely distractions for him to deal with on that landing approach, but I'd be speculating to say exactly what was going through his mind.
"he apparently only saw the one jumper who landed to the north and followed.
FMD rule
QuoteHe should have been continually monitoring the traffic and wind indicators and been prepared to adjust his pattern and approach accordingly. "
Chase the sock
Now you guys add in the bit about two guys landing opposite closes the area.
Great...all the canopies too low to adjust get hosed. All those still high enough are flying all over the place trying to adjust.
Just great.
You guys are scaring the hell out of me for the sake of all who fly there. The scariest part is you don't seem to see the problem and no amount of explanation, sarcasm, or plain rattle-your-cage affects your thinking.
I'm done. Sometimes you just have to say, "Fuck it".
QuoteQuotehe apparently only saw the one jumper who landed to the north and followed.
FMD rule
The first two jumpers down landed so close together in terms of time, it's likely that many in the air would not have been able to tell who was actually first down. How much time do you spend looking at any single canopy while monitoring the traffic in the pattern?
QuoteQuoteHe should have been continually monitoring the traffic and wind indicators and been prepared to adjust his pattern and approach accordingly. "
Chase the sock
Adjust your pattern and approach does not necessarily mean do a 180 and go the other way. It could mean something as simple as allowing more space for the flare and run out if you're landing downwind. Whatever the conditions, you're going to have to allow for ground winds in planning your approach. You're also going to have to allow for traffic. I've misread conditions on occasion and had to change my plan. I do so in accordance with the local rules and when I visit any new dropzone, I make a point of knowing what the local rules are.
QuoteNow you guys add in the bit about two guys landing opposite closes the area.
Just great.
I understand what you're saying, but I don't make the rules. I just try to follow them to the best of my ability. I'm sure that the Perris staff and management would love to hear your thoughts on how to run their DZ, though. Why don't you give them a call and rattle their cage?
Or perhaps you're trying to say there's nothing the guy could have done differently? If so, were you there? I was.
QuoteThe first two jumpers down landed so close together in terms of time, it's likely that many in the air would not have been able to tell who was actually first down. How much time do you spend looking at any single canopy while monitoring the traffic in the pattern?
exactly...and the POLICY at Perris is if you are in the air and this happens, then you land off the grass. the GRASS IS CLOSED. There are acres and acres of dirt fields to land in.
So you have to adjust your pattern (as brett said) in order to land out in the dirt.
The REAL issue here is that everyone had "grass envy" and ignored the pertinent rule. heaven forbid they get their jumpsuits dirty.
bigbearfng 18
Hmmm,
I'm sure "grass envy" does play a part in these things at times. However....
I'm also looking back to a mention above about the swooper coming in (or even just a late commitment to direction from anyone-be it "chasing the sock" or whatever) and folk behind him guessing his direction-there has been enough low turns that ended up in injuries; I don't want to see any more.
(And yes everyone "should" be able to safely flat turn etc. but obviously that isn't the case. That's another whole subject!)
And say you're lined up and then abort to the dirt on the side...now a canopy behind you-you're cutting across in front of them....and there's a potential canopy collision.....
I'm thinkin there is advantage to hangin back till the landing patterns well established.
And if it's lookin like a cluster developing, well then I like the dirt!
Just throwing more food for thought out there........
kallend 2,219
QuoteQuote
FMD ruleQuoteHe should have been continually monitoring the traffic and wind indicators and been prepared to adjust his pattern and approach accordingly. "
Chase the sock
Just great.
Which is why, when I'm on a big way at Perris, I generally land in the field behind the ultralights, well away from the madhouse on the grass. Usually it's just me and Melanie there. I figure if the DZO chooses to land there, it must be smart.
wmw999 2,643
I don't believe I've ever landed in the grass at Perris (and yes, I have jumped there ). I've pretty much only been there for bigways in the last 5 years. I don't remember anything before that -- I'm too old
Wendy P.
QuoteI'm also looking back to a mention above about the swooper coming in (or even just a late commitment to direction from anyone-be it "chasing the sock" or whatever) and folk behind him guessing his direction-there has been enough low turns that ended up in injuries; I don't want to see any more.
Wrong. Real swoopers flying recognizable pattern.
jsaxton 0
The BigWays were instructed:
"If you are landing in the state of California, you will land in the same direction as the first man down (usually Dan BC) if you do not, you may be sat down AND banned from ALL future events".
yup...and guess what? we STILL had idiots landing the opposite direction! And trust me, the organizers expedited themselves down in order to land much sooner than anyone else...and CERTAINLY soon enough for people to adjust accordingly.
Oh, did i mention we also had someone holding the tetrahedron in place and the organizer would ALWAYS land in that indicated direction?
So not only did you have the FMD rule, you had that FMD following the tetrahedron.
And we STILL had people completely oblivious.
This isn't about the particular rules at any given DZ. this is about paying attention under canopy, plain and simple.
wmw999 2,643
Were those people named and/or sat down? It might be time for some actual rather than threatened consequences. At least if there's a repeat offender. There are always realtime situations, but dang. It's not like they say you can't whine about having to land off and in a less-than-perfect direction.Quotewe STILL had idiots landing the opposite direction
Wendy P.
Didn't Perris change the rule for the main landing area so that it is restricted to B license and above? If this person really had <50 jumps, perhaps the main landing area wasn't the right place to be in the first place ... especially on a bigway weekend.
