polarbear 1 #1 June 21, 2007 I did a search on this an couldn't come up with anything. Anybody know if there is special technique needed for sewing HMA? I figured I'd use a straight stitch with E-thread and just hand-walk the machine to make sure I stayed in the middle of the line. Anybody know anything? Do I need a certain needle size? "Holy s*** that was f***in' cold!" Quote Share this post Link to post Share on other sites
Spizzzarko 0 #2 June 21, 2007 I would think that a dull needle would do better in that aspect than a sharp one as a dull needle would seperate the weave instead of sewing through a carrier. This is purely subjective thought though. Quote Share this post Link to post Share on other sites
darkwing 5 #3 June 21, 2007 I'll defer to the experts, but I'd probably use B-thread. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
Rdutch 0 #4 June 22, 2007 I wouldn't go for a dull needle. Dull needles will grab and tear the fibers. If you do sew Hma with a straight stitch (PD uses a bartack, but I have seen Precision canopies with a straight stitch.) you have to be very carefull to make every stitch the same length. While there isnt any reason why you cant straight stitch it, a bartack is more consistent, but you will need a machine that will make a small enough bartack. Also the very small hma is prone to breakage where the fingertrap ends so make sure you have a very sharp pair of scissors and make the cut very long. Hma isnt the easiest line to cut. Good luck! Ray Small and fast what every girl dreams of! Quote Share this post Link to post Share on other sites
riggerrob 644 #5 June 22, 2007 Similarly, remember to full straighten out the cut end. HMA is a "zero core" line, so even a tiny fold-over will weaken the outer line. Quote Share this post Link to post Share on other sites
riggerrob 644 #6 June 22, 2007 ... dull needle ... >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Bad idea. Dull needles usually have bent tips, sharp edges, etc. that cut fibers. Why not just continue to use the "ball-point" or "universal" needles that we normally use for sewing nylon? Oh! And a size 16 needle will do fine for sewing thin HMA lines. No need for the size 22 needles that we use for harness or container repairs. Similarly, skinny "B" Thread will work better on skinny HMA lines. Quote Share this post Link to post Share on other sites
precision 0 #7 June 22, 2007 QuoteI have seen Precision canopies with a straight stitch Precision does not use a straight stitch on HMA. It might look like a straight stitch, but it is a zigzag. It is imperative that you use a zig-zag stitch to prevent thread breakage. The zig-zag doesn't have to be much, but a straight stitch will definitely break on fingertrapped HMA. We use a new needle with every HMA lineset. George Galloway Precision Aerodynamics Quote Share this post Link to post Share on other sites
Spizzzarko 0 #8 June 25, 2007 I was un aware of that information. Sharp needles only then folks! Quote Share this post Link to post Share on other sites
