alexey 6 #1 June 8, 2007 So, description: I did buy 1ear and 2 ear oeticker clamp, and side jaws. The problem with 1-ear clamp for reserve: I put the clamp on type 4 9\16" tape. When I'm trying to press it, I've can squize it so much that I actually damafe the tape, but even after that ripcord housing can be moved out from clamp. I have to set heat-tybe over housing to fix housing from moving out of clamp. The problem with 2-ear clamp for cutaway: it made from alum, so, when I press jaws to set it, I can easelly broke clamp in between housings. How much force should be applyed on jaws? Which jaws should I use (there are 2 on device - one that closes totally, and one thet has some space between jaws?) How to fix reserve housing from moving? Thanks... Sorry for bad EnglishLexa Quote Share this post Link to post Share on other sites
alexey 6 #2 June 11, 2007 Noone uses that clamps???Lexa Quote Share this post Link to post Share on other sites
BKR 0 #3 June 11, 2007 Are you using the setting tools from Oeticker?Jérôme Bunker Basik Air Concept www.basik.fr http://www.facebook.com/pages/Le-Luc-France/BASIK-AIR-CONCEPT/172133350468 Quote Share this post Link to post Share on other sites
riggerrob 644 #4 June 11, 2007 QuoteNo one uses [Oetker] clamps??? >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Lots of factories now use Oetker clamps. The problem is that Oetker clamps are so much more durable - than hand sewing - that few field riggers have any experience replacing them. Quote Share this post Link to post Share on other sites
alexey 6 #5 June 11, 2007 QuoteAre you using the setting tools from Oeticker? Yep. One that Para-Gear sells there: http://www.paragear.com/templates/parachutes.asp?group=164&level=2&parent=27Lexa Quote Share this post Link to post Share on other sites
BKR 0 #6 June 11, 2007 This is the one we used. Beware to not squeeze to much. We do not have any problem with this.Jérôme Bunker Basik Air Concept www.basik.fr http://www.facebook.com/pages/Le-Luc-France/BASIK-AIR-CONCEPT/172133350468 Quote Share this post Link to post Share on other sites
alexey 6 #7 June 11, 2007 QuoteThis is the one we used. Beware to not squeeze to much. We do not have any problem with this. As I understend - for twin clamp you uses side jaws (one with space between jaws) - to dont damage clamp and for I ear you uses top jaws (that closes complitely) - to fix housing - right?Lexa Quote Share this post Link to post Share on other sites
BKR 0 #8 June 11, 2007 YesJérôme Bunker Basik Air Concept www.basik.fr http://www.facebook.com/pages/Le-Luc-France/BASIK-AIR-CONCEPT/172133350468 Quote Share this post Link to post Share on other sites
