woodpecker 0 #1 August 18, 2006 I want to run two monitors simo and not sure how. Please help.SONIC WOODY #146 There is a fine line between cockiness and confidence -- which side of the line are you on? Quote Share this post Link to post Share on other sites
Amazon 7 #2 August 18, 2006 Go Google MULTIMON.. you need the hardware tha will support it.... and that is it. Quote Share this post Link to post Share on other sites
Mostly_Harmless 0 #3 August 18, 2006 QuoteI want to run two monitors simo and not sure how. Please help. If your video card has two ports on it then you are all set. I run dual monitors at home and at work._________________________________________ www.myspace.com/termvelocity Quote Share this post Link to post Share on other sites
LisaM 0 #4 August 18, 2006 If your video card does not have dual plugs, get another video card and plug one into each. The only issue with that is sometimes the colors are a bit off and it can get annoying if you are anal! ~ Lisa ~ Do you Rigminder? Quote Share this post Link to post Share on other sites
ifall 0 #5 August 18, 2006 Are you wanting to show the same view on both monitors or use the two in conjunction as one big screen? The latter is what I do and I have a video card with one output that splits to two. You have to have a special video card to use them as one big screen. Quote Share this post Link to post Share on other sites
woodpecker 0 #6 August 18, 2006 Yes, use them both as one big screen. Problem is I dont think my desktop has an AGP slot. I'm pretty sure its all PCI and to my knowledge, AGP are the only duel monitor vid. cards. Is this correct, or does PCI make one?SONIC WOODY #146 There is a fine line between cockiness and confidence -- which side of the line are you on? Quote Share this post Link to post Share on other sites
Mostly_Harmless 0 #7 August 18, 2006 QuoteYes, use them both as one big screen. Problem is I dont think my desktop has an AGP slot. I'm pretty sure its all PCI and to my knowledge, AGP are the only duel monitor vid. cards. Is this correct, or does PCI make one? AGP and PCI-E can handle dual monitors. You can get a PCI card and use that to handle the graphics along side your exsisting card (PCI, PCI-E, AGP are ports not companies)._________________________________________ www.myspace.com/termvelocity Quote Share this post Link to post Share on other sites
meridianjumper 0 #8 August 18, 2006 You can check out New Egg online and search for Dual Video. Not sure if you have a VGA or the newer style connection. Expect to pay at least $75 for one. Blue Skies, Jeremy Quote Share this post Link to post Share on other sites
BIGUN 1,488 #9 August 18, 2006 1. Plug in the monitor. 2. Right click on the desktop. 3. Select "Properties." 4. Select the tab, "Settings." 5. What type of display? 6. If it supports multiple monitors, it'll say. If not, run to BB and pick a new card with memory. Plug it in. 7. Repeat Steps 2-4 8. View attachment 9. The 2 monitor screens labeled 1 & 2 are positioning for your cursor drag (if the external is on the left like mine and you want the cursor to go left, set it up like mine. 10. If you want it the opposite way, drag the monitor 2 to the other side. 11. Highlight the monitor and Play with the checkbox "Extend my windows desktop on this monitor" till you're satisifed. Enjoy... My next montior is a four headed dragon. Or a couple of 30 inchers.... "More power" ...Tim AllenNobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
