mnskydiver688
Attn Riggers... Flexon Question
I bought a Flexon from a guy at the DZ and so far I have been happy with it. I checked another thread regarding Flexon's and didn't quite get the answer I was looking for. What I am wondering is on the main pin flap is there a way to stow the tuck tabs better? I have tried pushing the two tabs together when I tuck them underneath but sure enough move around in the plane a bit and the flap comes undone. Is there a way to make that more secure or just go with it. I am only doing RW so FF is not an issue, but being me I hate to have something happening like that in the plane before I even get out.
Sky Canyon Wingsuiters
Those "walrus tooth" tabs usually work very well unless they get a bend in them, so check for that. The principle of the way they work is that they can bend to make it easy to tuck them in, but then must remain fairly straight to hold the flap well. If you can't get them to stay straight you might contact the manufacturer, Rigging Innovations, for replacements, or ask a knowledgeable rigger to make new ones.
The Flexon was an innovative rig when it was first introduced in the early 90s owning to making ring articulation popular in the sport. I put together some of the early Flexon print advertisements that ran in SKYDIVING and PARACHUTIST. Anyone remember, "It's Not Just a Gear Choice, It's an Attitude . . ." That was mine, LOL.
It was also the first rig to make use of a fabric called "Antron." Not all of them had it, but a couple of tips are if the Antron starts to fuzz up an electric razor cleans things up nicely. You could also spill beer on it would just bead up. The sport's a bit different nowadays, but that was a worthy selling point back then.
On a side note the evolution of riser covers and tuck tabs are worth a mention here. It used to be we jumped rigs that had no riser covers at all. And an often seen sight in those days was being in a RW formation and looking over to see someone's steering line floating a few feet above their rigs. Its why, to this day, most old timers are so anal about stowing their control lines and toggles so securely. Now the opposite is happening as riser covers work so well (on most rigs) many folks don't stow their excess control line at all. I think its nuts taking a chance on two big fat loops floating around if you have some kind of weird malfunction, but it seems many don’t worry about it.
Also there's a notion in the sport that since the advent of free flying every rig built prior is obsolete, and that's baloney. So, as long as it's fully airworthy, enjoy your Flexon . . .
NickD :)BASE 194
Is your finished pack job, flat and smooth across the top of the container when you are finished packing? I've seen where, 'bulky' 'rounded' looking pack jobs tend to form a gap between the flaps ant the tuck tabs will pop out. Is your main parachute within size guidelines for that container?
Chuck
Hmmmm... I've got a Talon94, okay, not a Flexon, but closer then not... and I've got a Raven 2g reserve in it (218 sq ft) and a Sabre 170 main in it. The main closing loop is about the same for me; just long enough to stack the gromets on top of each other, but I've never had problems with the main pin flap coming open on it.
Can you post photos?
