browncow 0 #1 May 2, 2007 I have a javelin odyssey thats a couple hundred jumps old.I have just noticed that the main closing pin has scored/scratched the grommet on the flap and the outside edge of the pin is roughed up from this contact.The pin doesn't actually have any burs on it just a bit rough.My closing loop is ok,no excessive wear and i dont think the outer curve of the pin actually comes into contact with the loop on opening anyway.Is this roughing up of the pin normal. Quote Share this post Link to post Share on other sites
Tonto 1 #2 May 2, 2007 I don't think it's normal. I've had several rigs, some with 1000's of dives on them and have never noticed pin/grommet wear. Are the grommets stainless or brass? tIt's the year of the Pig. Quote Share this post Link to post Share on other sites
Tonto 1 #4 May 2, 2007 I think some high res pics should clear this up. Just had a look at my oldest rig, which has about 700 jumps on it, and you can see there has been contact - but I wouldn't refer to the pin as scratched. tIt's the year of the Pig. Quote Share this post Link to post Share on other sites
councilman24 37 #5 May 2, 2007 Stainless or nickle plated? I see dents and bumps but not usually "rough" like sandpaper.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
riggerrob 644 #6 May 2, 2007 To smooth the pin, just rub it with emery cloth (fine sandpaper). To smooth the grommet, ask your rigger to re-set it. If the grommet is really rough, it will have to be replaced. Quote Share this post Link to post Share on other sites
