Yossarian 0 #1 April 24, 2007 my uni club has two rigs at present, a pilot 188 in an icon sport and a triathlon 170 also in an icon sport. i know that both containers will fit both canopies as per the sizing chart, what do i have to think about when changing them over? (harnesses are different sizes, somebody wants to jump the 170 but cant fit into the h/c its in at the moment). as both containers are icons, same age, both with mini-risers, im pretty sure i dont have to swap d-bags/risers etc and as far as i can tell the process would be to unpack both, cut them away, re-attach them to their 'new' containers and repack them after a careful check of both the lines (making sure theyre all in the right place etc) and the 3 rings. is there anything im missing or need to think about? it seems simple enough, just making sure... thanks for your help Quote Share this post Link to post Share on other sites
DougH 270 #2 April 24, 2007 Quote is there anything im missing or need to think about? it seems simple enough, just making sure... thanks for your help I would add that you should do a four line, instead of the normal run up the lines that most of us do before pro packing. You might have ment that, but I didn't see it mentioned. Also make sure the white loop is routed correctly through the terminal and the rsl is hooked back up properly on the riser. It does NOT clip on to the large base ring. "The restraining order says you're only allowed to touch me in freefall" =P Quote Share this post Link to post Share on other sites
fcajump 164 #3 April 24, 2007 Quotemy uni club has two rigs at present, a pilot 188 in an icon sport and a triathlon 170 also in an icon sport. i know that both containers will fit both canopies as per the sizing chart, what do i have to think about when changing them over? (harnesses are different sizes, somebody wants to jump the 170 but cant fit into the h/c its in at the moment). as both containers are icons, same age, both with mini-risers, im pretty sure i dont have to swap d-bags/risers etc and as far as i can tell the process would be to unpack both, cut them away, re-attach them to their 'new' containers and repack them after a careful check of both the lines (making sure theyre all in the right place etc) and the 3 rings. is there anything im missing or need to think about? it seems simple enough, just making sure... thanks for your help Make sure the reserve is still appropriate for the jumper weight. JWAlways remember that some clouds are harder than others... Quote Share this post Link to post Share on other sites
riggerrob 644 #4 April 24, 2007 Start by staring at the data panels (under the shoulder yoke, about tit level). The data panels should include the container size (i.e. "I5"). If both rigs are the same size, you can swap deployment bags along with pilot chutes and risers. Quote Share this post Link to post Share on other sites
riggerrob 644 #5 April 24, 2007 Start by laying both rigs on the packing mat, side-by-side. Pull the pilot chutes and deployment bags out, just far enough to straighten out the main risers. Lay books, packing weights or the laziest club member across the main risers. Pull both cutaway handles. Clean cutaway cables. Re-insert cutaway handles into harnesses. Leave the main risers, etc. laying on the packing mat. Swap harnesses. Re-connect the main risers, remembering to keep cutaway handles with their original harnesses. Wake-up up lazy club member. Stretch out main canopies. Do line continuity checks. Pack mains. Skydive. Quote Share this post Link to post Share on other sites
pincheck 0 #6 April 24, 2007 should he not disconect any rsl fitted first before pulling the cutaway handles ? Billy-Sonic Haggis Flickr-Fun Quote Share this post Link to post Share on other sites
DeNReN 0 #7 April 24, 2007 and....dont forget to check that the closing loops are the appropiate length...as the Tri 175 should pack a little smaller. Quote Share this post Link to post Share on other sites
Yossarian 0 #8 April 25, 2007 thanks, had all that covered except the closing loops but im sure that would have made itself apparent when i closed the container cheers for your help Quote Share this post Link to post Share on other sites
