skydonkey 0 #1 April 22, 2007 Hi there, I have a Mirage G3, which is sized for 150-135. I had a Sabre1 150 in it, but I am planning on putting a Spectre 135 in its place. I've heard that the spectre has a smaler pack volume, size for size than a 9 cell, so could this leave me with a sloppy container? Many thanks Quote Share this post Link to post Share on other sites
tkhayes 348 #2 April 22, 2007 probably - the Spectre packs much smaller. It is already smaller in size, and with only 7 cells, then it will eb loose. Maybe get the Dacron lines will help with bulk and with softer openings. Quote Share this post Link to post Share on other sites
FireMedicJumper 0 #3 April 22, 2007 I think it would depend on what size container you have. By that I mean is it already at the bottom end of its size range with the 150 in it? On all the Mirage containers I have seen, the range of canopy sizes is usually listed on a label inside the main pack tray. I would expect the Spectre to have a slightly smaller pack volume, but not so much so as to cause a problem that couldn't be solved by adjusting the closing loop length if the container is sized correctly. Of course if you really want to know for sure don't take my word for it. Check out Mirage's container sizing guide. http://www.miragesys.com/DesignOrder/SizingGuideByContainer.aspx Quote Share this post Link to post Share on other sites
hjumper33 0 #4 April 22, 2007 Id say its close to a half size difference. I had a spectre 170 demo and then went down to a sabre1 150, and id say the spectre only packed slightly larger. It depends on how old the sabre was and how new the spectre is as well. Quote Share this post Link to post Share on other sites
packing_jarrett 0 #5 April 23, 2007 Quoteprobably - the Spectre packs much smaller. It is already smaller in size, and with only 7 cells, . Number of cells doesn't change pack volume (ie 7 vs 9 cell) 135 sq ft is 135 sqftNa' Cho' Cheese Quote Share this post Link to post Share on other sites
IanHarrop 43 #6 April 23, 2007 I looked at this chart and there are some differences between canopies that are advertised as the same size in terms of square feet. I know some of this is due to manufacturers measuring differently when calculating sq feet. Could some of it also be due to more cells means more ribs means more fabric means more volume? http://www.dropzone.com/files/archive/gear/Canopy_vols.html"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
FireMedicJumper 0 #7 April 23, 2007 The seven cell canopy should pack somewhat smaller although it might be difficult to tell much difference. It has less fabric due to fewer ribs etc. the same way a airlock canopy will pack slightly larger and a cross brace canopy will pack even larger still due to all the extra fabric. Quote Share this post Link to post Share on other sites
phoenixlpr 0 #8 April 23, 2007 QuoteNumber of cells doesn't change pack volume (ie 7 vs 9 cell) Really? Just more lines, more ribs and more stitching. (9cell vs 7cell) Quote Share this post Link to post Share on other sites
darkwing 5 #9 April 23, 2007 QuoteQuote...Number of cells doesn't change pack volume (ie 7 vs 9 cell) 135 sq ft is 135 sqft I will disagree very strongly with this statement. Seam bulk is very significant compared to non-seam fabric. Otherwise identical canopies, with one being 7 and one being 9 cells will have a significant, noticeable volume difference due to the extra seams. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites wmw999 2,623 #10 April 23, 2007 All that said, I'm going to suggest that the container doesn't have to look sloppy. I've been putting a 7-cell 135 into a container designed for a 150 for the last 3 years with no problems. No pin slippage, no problem with it looking bad. Just much easier pack jobs . I use the bag sized for the container. Wendy W. There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites bliston 0 #11 April 23, 2007 Agreed. In fact, I've been using canopies that are "a size down" from recommended for years. The main tray will feel a bit softer, but not sloppy. Now if you put in a main d-bag a size or two smaller, that might lead to more cosmetic issues and pin slippage... but the canopy (especially if it's on the newer side) will expand to fill the bag. BenMass Defiance 4-wayFS website sticks! Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
