bertusgeert
Computer Help: Disk Defrag
Allright, my gf's 2 year old laptop is in dire need of some help. It is running VERY slowly.
I ran disk cleanup on it first and deleted more than 2G of files.
Then I ran Disk Defragmenter a few times. Look at the pictures to see before and after the two processes.
Now, will it help to keep running Disk Defragmenter a 100 times? It changes so little every time I run it now that I think this would be neglegable.
The computer now runs faster, but is still pretty ridiculously slow.
The battery is also non-existent - rans for 5 minutes before it can't anymore.
Thanks!
As jy dom is moet jy bloei!
Windows defrag sucks.
Get something like perfect disk. That will make a much bigger difference.
If it is running slow there is most likely a bunch of software that is running that doesn't need to be some of which is spyware, take a look and get rid of what you can.
~D
Sorry, should have mentioned:Already ran Ad-Aware and Spybot.
I will take a look for perfect disk.:)
[RED]* WARNING *[/RED]
Modifying your registry incorrectly can cause your computer to become unbootable, and require you to reload Windows. Do it at your own risk.
Start - Run
Type "regedit" without the quotes.
Navagate to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
This is the list of programs that start when you boot. If you notice a program that doesn't belong, delete the entry. Also check out:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Also you should look into getting the battery replaced if it's only hold a five minute charge.
Smoking is a combination test for intelligence and resistance to marketing/peer pressure. All smokers have failed at least one of these.
One other thing to mention is that there is an effect caused by other computers that make you think your computer is slower than it really is.
I run into this a lot at work because we are unable to replace the office computers every year, more like every 5-6 years we are replacing them. People end up buying or using a computer around thier home that is much faster than the one they use at work and complain that thier computer is slowing down. In reality, they are just getting used to something that is faster and they need to learn to make due.
But in your case, that harddrive really is fragmented.
~D
