Grips 0 #1 December 5, 2006 According to dictionary.com: fly1 /flaɪ/ Pronunciation Key - Show Spelled Pronunciation[flahy] Pronunciation Key - Show IPA Pronunciation verb, flew or, for 11, 19, flied, flown, fly·ing, noun, plural flies. –verb (used without object) 1. to move through the air using wings. (we don't have wings) 2. to be carried through the air by the wind or any other force or agency: bits of paper flying about. (we're not really being 'carried', but that doesn't matter, because it doesn't specify whether 'carried' is vertically, or horizontally through the air) 3. to float or flutter in the air: flags flying in the breeze. (well, we're not floating for sure, however some of us might be fluttering) 4. to travel in an aircraft or spacecraft. (we're not in space, but that doesn't matter because vertical or horizontal doesn't really exist in space, or does it?) 5. to move suddenly and quickly; start unexpectedly: He flew from the room. (we're not in a room, unless you consider the sky the room, but we are moving suddenly, and quickly) 6. to change rapidly and unexpectedly from one state or position to another: The door flew open. (yeah, that does happen) 7. to flee; escape. (well now, there is a few jokes in that one) 8. to travel in space: The probe will fly past the planet. (Again, vertical, or horizontal, or does it matter? We are not flying PAST the planet however, we are flying, or moving, towards it) 9. to move or pass swiftly: How time flies! (yeah, I suppose, a bit vague though) 10. to move with an aggressive surge: A mother fox will fly at anyone approaching her kits. (yeah, that happens) I don't know. Is vertical falling flying? Quote Share this post Link to post Share on other sites
Icon134 0 #2 December 5, 2006 Quote1. to move through the air using wings. (we don't have wings) speak for yourself... I use wings all the time... Livin' on the Edge... sleeping with my rigger's wife... Quote Share this post Link to post Share on other sites
cocheese 0 #3 December 5, 2006 I'm still flying from some of the memories made in the sky. Quote Share this post Link to post Share on other sites
Grips 0 #4 December 5, 2006 Does a 'wing' have to provide lift to be a 'wing'? If it does, then your not really using wings. Quote Share this post Link to post Share on other sites
2fat2fly 0 #5 December 5, 2006 Yes, by definition #2-If we weren't being carried by the wind, there'd be no need to adjust the spot to compensate for the uppers.I am not the man. But the man knows my name...and he's worried Quote Share this post Link to post Share on other sites
Peej 0 #6 December 5, 2006 In the sky your whole body is a wing Advertisio Rodriguez / Sky Quote Share this post Link to post Share on other sites
Icon134 0 #7 December 5, 2006 QuoteDoes a 'wing' have to provide lift to be a 'wing'? If it does, then your not really using wings.um... that's exactly why I have wings... to provide a bit more lift then the RW group I'm filming. my wings may not provide enough lift to stay off the ground indefinetely but... they do provide lift. oh, and what peej,2fat2fly said are also true... Livin' on the Edge... sleeping with my rigger's wife... Quote Share this post Link to post Share on other sites
bozo 0 #8 December 5, 2006 Long ago, as a new jumper, I was regaling my five year old daughter...whos now 31.....with tales of how I could fly in freefall. She popped my balloon with this comment....."sure daddy....but you can go back up" Out of the mouths of babes. bozo Pain is fleeting. Glory lasts forever. Chicks dig scars. Quote Share this post Link to post Share on other sites
Grips 0 #9 December 5, 2006 So, you are providing a 'bit more lift' but its still falling. Lift: The lift force, lifting force or simply lift consists of the sum of all the fluid dynamic forces on a body perpendicular to the direction of the external flow approaching that body. Unless you can fly back up to 14,000 feet, I don't think those are wings, or somewhere there of, I don't think they are wings. Quote Share this post Link to post Share on other sites
Icon134 0 #10 December 5, 2006 QuoteLift: The lift force, lifting force or simply lift consists of the sum of all the fluid dynamic forces on a body perpendicular to the direction of the external flow approaching that body.um... this definition doesn't require that the force entirely counter that of gravity...Livin' on the Edge... sleeping with my rigger's wife... Quote Share this post Link to post Share on other sites
piisfish 140 #11 December 5, 2006 QuoteUnless you can fly back up to 14,000 feet, I don't think those are wings, or somewhere there of, I don't think they are wings. drop a Boeing/Airbus/Whatever from 14kft, do you think once it has obtained enough speed to not be in a stall, it can climb to 14k again ? Therefore I hereby declare that Boeings, Airbi (is that the plural for Airbus ??) etc DO NOT HAVE WINGSscissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
Grips 0 #12 December 5, 2006 Correct, but it does say perpendicular. Only unless your 'wing' creates a right angle, perpendicular to relative airflow, then it is not a wing and does not create lift. Quote Share this post Link to post Share on other sites
jakee 1,628 #13 December 5, 2006 QuoteQuoteLift: The lift force, lifting force or simply lift consists of the sum of all the fluid dynamic forces on a body perpendicular to the direction of the external flow approaching that body.um... this definition doesn't require that the force entirely counter that of gravity... But it does say perpendicular to the external flow, which excludes camera wings (while falling down the tube) which produce drag parallel to the external flow approaching the body. Doesn't exclude components of tracking and wingsuit lift thoughDo you want to have an ideagasm? Quote Share this post Link to post Share on other sites
Grips 0 #14 December 5, 2006 They are wings, and we are flying (even if we don't have wings. While the common meaning of the term "lift" suggests an "upwards" action, in fact, the direction of lift (and its definition) does not actually depend on the notions of "up" and "down", e.g., as defined with respect to the direction of the gravity. Specifically, the term negative lift refers to the lift force directed "down". Quote Share this post Link to post Share on other sites
Icon134 0 #15 December 5, 2006 QuoteCorrect, but it does say perpendicular. Only unless your 'wing' creates a right angle, perpendicular to relative airflow, then it is not a wing and does not create lift.again nothing wrt the magnitude... my wings are also useful in "side sliding" oh, and I like how you only provide one defintion of Lift.Livin' on the Edge... sleeping with my rigger's wife... Quote Share this post Link to post Share on other sites
Grips 0 #16 December 5, 2006 I provided the most relevant definition to lift, not 36 plus irrelevant, unsubjective definitions. In the end it was also concluded that all of us are flying, not just the one with wings. Sorry to upset you. Quote Share this post Link to post Share on other sites
DougH 270 #17 December 5, 2006 Shut up and jump!!!! All I am thinking about most of the time is getting back up there, why are you worried about the definition of flying? (Probably the same reason I am replying!!!) I have to be flying, because I really suck at all the stuff that involves me standing up on my feet. Running, walking, dancing... not so good. "The restraining order says you're only allowed to touch me in freefall" =P Quote Share this post Link to post Share on other sites
kelel01 1 #18 December 5, 2006 I'd have to say "no". We're "falling with style", a la Buzz Lightyear. Quote Share this post Link to post Share on other sites
Lindercles 0 #19 December 5, 2006 Because of the very nature of language itself, and the function of the dictionary therein (which is to say descriptive, not prescriptive), the word "fly," just like any other word in any other language ever conceived, relies entirely on the people who use it for its definition, which is dynamic, rather than static, especially as relates to time. In other words, we're flying because we say we're flying. Quote Share this post Link to post Share on other sites
kkeenan 14 #20 December 5, 2006 We plummet. plum·met –verb (used without object) 3. to plunge. —Synonyms 3. fall, dive, drop, swoop. _____________________________________ Dude, you are so awesome... Can I be on your ash jump ? Quote Share this post Link to post Share on other sites
JohnMitchell 16 #21 December 5, 2006 QuoteSo, you are providing a 'bit more lift' but its still falling. Lift: The lift force, lifting force or simply lift consists of the sum of all the fluid dynamic forces on a body perpendicular to the direction of the external flow approaching that body. Unless you can fly back up to 14,000 feet, I don't think those are wings, or somewhere there of, I don't think they are wings. So flying a glider is not flying? They don't climb in still air, just come down. I'll bite on this hook of yours and say that freefallers are "falling", not "flying". But anyone tracking well or flying a birdman suit meets my definition of flying, which is generating lift that will move you across the sky. Quote Share this post Link to post Share on other sites
Calvin19 0 #22 December 5, 2006 well, as all things, it depends on how you read it (like NPS law) a wing is synonomous with a foil. and foil is just as loose a term. in old science a foil would be defined as aplate )wing) that creates a force while moving though bernoulli effect. now that we has almost entirely disprovved the bernoulli effect in the way of flying, ok..nevermind, its the same thing yes we are flying, we uses our extrmities as foils, our whole body is a foil, (DEFINATLY while tracking). we use the dynamic dissplacement of air to control our paths through a gas media. hell, a submarine is flying, as is a blimp. Quote Share this post Link to post Share on other sites
Johnnysgirly 0 #23 December 5, 2006 I say if Rachel Ray can get E.V.O.O. into the dictionary, we can add skydiving into the definition of flying. But that's just my opinion. Quote Share this post Link to post Share on other sites
Lindercles 0 #24 December 5, 2006 QuoteI say if Rachel Ray can get E.V.O.O. into the dictionary, we can add skydiving into the definition of flying. But that's just my opinion. Yeah, that's pretty much a succinct version of what I said. Quote Share this post Link to post Share on other sites
Icon134 0 #25 December 5, 2006 QuoteSorry to upset you.I wasn't upset... just bored... Livin' on the Edge... sleeping with my rigger's wife... Quote Share this post Link to post Share on other sites
