flyusa 0 #1 February 13, 2007 Any info would be helpful -thanks!There are many in government who have a very simple tax proposal in mind. There will be only two lines on the tax form: 1-How much did you make last year? 2-Send it. Quote Share this post Link to post Share on other sites
yeyo 1 #2 February 13, 2007 u talking about the freefly open face z1 right? if u are, i did. i used a L bracket from bonehead, a home made camera condom from an old wetsuit and i have a sony hc36 with a .43 fisheye lens. i bought a chincup from parasport and a helmet cutaway. have around 30 jumps with it and im satisfied.HISPA #93 DS #419.5 Quote Share this post Link to post Share on other sites
damion75 0 #3 February 13, 2007 Surely did. I have a parasport italia C bracket on the left, with a PC 109 mounted in it in a camera condom. I also rans a hypoxic hypeye to it although that is a recent addition. I also fitted the PSI chin cup which is ok. Of course I had about 400 jumps when I did all of that but that is probably not something that you want to think about... If your profile is correct, can I suggest that you take a look at this thread... Camera Jumper with 100 jumps in trouble thread*************** Not one shred of evidence supports the theory that life is serious - look at the platypus. Quote Share this post Link to post Share on other sites
piisfish 140 #4 February 13, 2007 just make sure you chance the opening system of the helmet, as the stock Parasport strap does NOT release under tension.scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
damion75 0 #5 February 15, 2007 Quotejust make sure you chance the opening system of the helmet, as the stock Parasport strap does NOT release under tension. Actually the stock strap appears to have changed - my camera helmet came with the seat belt type clip which was tough to open in any conditions (I got rid of it whe I fitted the chin cup). The one that I won in the Empuria Xmas draw has a really basic standard clip which is quite different.*************** Not one shred of evidence supports the theory that life is serious - look at the platypus. Quote Share this post Link to post Share on other sites
flyusa 0 #6 March 4, 2007 It's weird that I was jumping at Titusville the day before that incident. I ask about that particular helmet only because I just bought one and had plans to do video at some point in the future. I plan on getting a coach rating prior to shooting video, and don't plan on going for that until I have quite a few more jumps. Being a jump pilot at a single aircraft DZ means I won't get to that for a looooooong time. Thank you for pointing out the incident to me.There are many in government who have a very simple tax proposal in mind. There will be only two lines on the tax form: 1-How much did you make last year? 2-Send it. Quote Share this post Link to post Share on other sites
damion75 0 #7 March 12, 2007 No worries - just something to think about. As for the helmet, I didn't buy it with any intention of mounting a camera on it, but when I saw that they had brought out a chin cup fitting I decided to give it a try (for coaching mainly as well actually!)and it has worked out just fine. Solid fitting, fairly comfy etc. Certainly not the best set up available, but a couple of hundred bucks cheaper than going and buying a whole new set up! *************** Not one shred of evidence supports the theory that life is serious - look at the platypus. Quote Share this post Link to post Share on other sites
