slotperfect 7 #1 February 6, 2007 QuoteStatus: Mandatory inspection before next jump Identification: All tandem loop style reserve ripcords manufactured by Relative Workshop prior to October 2004. Identified by black shrink wrap on the swage.Arrive Safely John Quote Share this post Link to post Share on other sites
JohnRich 4 #2 February 6, 2007 QuoteMandatory inspection before next jump For what, specifically, are they being inspected? If there's a problem, unless someone knows what to look for, they might miss it. Quote Share this post Link to post Share on other sites
IanHarrop 43 #3 February 6, 2007 Link to service bulletin: http://www.unitedparachutetechnologies.com/PDF/Support/Product%20Service%20Bulletins/PSB300107.pdf "Service Bulletin: Uninsured United Parachute Technologies, LLC requires that all tandem loop style reserve ripcords with black shrink wrap on the swage are inspected (instructions attached) for any broken filaments. If found, ripcord needs to be replaced immediately. Since October 2004, clear shrink wrap is used to visibly inspect the filaments.""Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
klingeme 1 #4 February 6, 2007 Here is a copy of the Service Buletin. The affected ripcords are identified by black shrink wrap on the swedge. http://www.unitedparachutetechnologies.com/PDF/Support/Product%20Service%20Bulletins/PSB300107.pdf Mark Klingelhoefer United Parachute Technologies edited to include link as attachment was too large. Quote Share this post Link to post Share on other sites
Samurai136 0 #5 February 7, 2007 I am somewhat unclear on the language. What are the attached instructions? Are the attached instructions?: If you have black heat shrink... Remove black heat shrink wrap; Inspect; replace if frayed cables are discovered? thats how I'm reading it."Buttons aren't toys." - Trillian Ken Quote Share this post Link to post Share on other sites
slotperfect 7 #6 February 7, 2007 Sorry . . . I uploaded the PDF in a hurry this morning and it was too big so it didn't show up. The link has now been posted - thanks!Arrive Safely John Quote Share this post Link to post Share on other sites
sundevil777 102 #7 February 7, 2007 The instructions don't say what to do if the ripcord is OK, such as apply clear heat shrink tubing or just leave it off. I would hope that black shrink tubing isn't used, because then it would need to be inspected again. I don't understand how a service bulletin could be issued that neglects to address this.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
klingeme 1 #8 February 8, 2007 The Bulletin has been corrected to include adding clear shrink wrap if ripcord is not damaged. Mark Klingelhoefer United Parachute Technologies Quote Share this post Link to post Share on other sites
riggerland 0 #9 February 17, 2007 The Bulletin has been corrected to include adding clear shrink wrap if ripcord is not damaged => OK but someone knows if the clear shrink wrap goes inside the hole of the washer ? since the shrink wrap diameter is only 1/4 ", I guess that even by squeezing the clear shrink wrap, it cannot go above a 1/2 inch washer !!! does someone already tried or know the answer ? Quote Share this post Link to post Share on other sites
sundevil777 102 #10 February 17, 2007 What washer, I can't tell from the pictures where it is.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
ericfradet 0 #11 February 17, 2007 What washer, I can't tell from the pictures where it is. There is a washer on ALL tandem loop style reserve ripcord from UPT, right above the swage, but they do not show it on pictures .. Quote Share this post Link to post Share on other sites
PhreeZone 20 #12 February 23, 2007 Has anyone found a good heat shrink tubing that works for this? Are you using a 3-1 or a 4-1?Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
ericfradet 0 #13 February 24, 2007 Has anyone found a good heat shrink tubing that works for this? Are you using a 3-1 or a 4-1? After asking UPT, they said that the 1/4 inch clear shrink wrap goes over the the 1/2 inch washer ( by putting the washer flat and squeezing the shrink wrap). to answer your question I found a very good clear shrink wrap, I use a 4-1 it comes in 12 mm = 1/2 inch or a 8 mm = 0.31 inch but the seller is located .........in France Quote Share this post Link to post Share on other sites
Spy38W 0 #14 February 24, 2007 QuoteHas anyone found a good heat shrink tubing that works for this? Are you using a 3-1 or a 4-1? After asking UPT, they said that the 1/4 inch clear shrink wrap goes over the the 1/2 inch washer ( by putting the washer flat and squeezing the shrink wrap). to answer your question I found a very good clear shrink wrap, I use a 4-1 it comes in 12 mm = 1/2 inch or a 8 mm = 0.31 inch but the seller is located .........in France Pardon my french, Merci beaucoup! -- Hook high, flare on time Quote Share this post Link to post Share on other sites
pchapman 280 #15 February 26, 2007 It's a little disappointing to see the way United Wonderhog Technologies (or whatever their name) wrote their bulletin. First the nitpicking: Page 1 says #300107. Page 2 says #301007. Both pages say "Quality Assurance Department."... The bulletin does not note that it is changed in any way. The number is the same, the date is the same... but the content is different (adding the clear heat shrink). I've already complied with the first version of the bulletin, but now my work doesn't match what I wrote down as having been complied with. Finally, they continue to make the whole bulletin mandatory before the next jump. So one can't jump the rig unless one has gone out, searched around, and found the right type of heat shrink. Sigh. [Edited to add: I don't want to be harsh on them, but any sloppiness in writing a service bulletin has a significant effect, especially on any rigger trying to do things by the book, as the FAA expects.] Quote Share this post Link to post Share on other sites
