everymansaved
Mass Storage Controller? Computer Geniuses Please Help!
If anyone out there is well versed in Win XP, I need your help. I seem to be unable to get my built in SD card reader to work anymore, and when I took a look at the device manager, a device called a "Mass Storage Controller" under the catagory "Other Devices" is not functioning, and windows can't seem to install a driver for it. Does anyone know how I can remedy this? Thanks!
Sean LR
God made firefighters so paramedics would have heroes...and someone can put out the trailer fires.
Erm... well. It might have just fried (which is a little rare). If that is the cause just get an external card reader, or look at your printer and see if it has one (Win XP will recognize the card readers on a printer automatically... usually...)
"People demand freedom of speech to make up for the freedom of thought which they avoid." - Kierkegaard
It probably gave a little more detail than just "it failed"
what changes did you make recently? How long has it worked and when did it stop working? What were you doing / changing when it stopped? What other hardware have you installed recently?
Owned by Remi #?
"...The wizard could not find the required software." I haven't installed anything recently, it worked for ~2 months, and stopped working ~2wks ago. I wasn't really doing anything when it stopped, I just tried to use it one day, and it was defunct.
The Windows driver installer almost never works on its own, especially where unusual devices (e.g., SD card readers) are concerned: they are very vendor-specific.
Download the driver from the vendor's website and point the System Properties installer to that.
Speculation as to cause? The driver got corrupted somehow. Better do a drive integrity check. Use your system tools to check for OS errors / missing data.
mh
"The mouse does not know life until it is in the mouth of the cat."
To add to what Mark said, there's been times that I've had to completely delete the device from the device manager and re-install the vendor's driver software from scratch.
Nobody has time to listen; because they're desperately chasing the need of being heard.
Alright, more confusion comes this way... I guess I should have looked further down the list, but the device with the error must have caught my eye before I could realize that there is a "Secure Digital Host Controller" or something to that effect on the list as well. Is the Mass Storage Controller some kind of adjunct to the SD reader?
Computer make & model, please.
And is it possible for you to give us an exploded view of what you're looking at - like attached?
Are you looking under the Storage Controller or the SD Host adapters?
