kkeenan
Space Fans
For all you space fans, who are interested in more than the antics of the Crazy Astro Stalker Chick, here's some info on the next shuttle mission, STS-117.
The orbiter Atlantis moved today from its hanger to the Vehicle Assembly Bldg. at Kennedy Space Ctr., where it will be mated to the External Tank and Solid Rocket Boosters. Also today, the next piece of the International Space Station was loaded into the Payload Canister for transportation to the launch pad. This component, (see photo) called the S3/S4 Truss, is about the size of a school bus and weighs about 25,000 lbs. The payload will be loaded into Atlantis' payload bay next week at the launch pad. This piece will attach to the starboard (right) end of the Truss structure of ISS and contains a large set of solar panels just like the ones that were attached to the other side late last year.
Atlantis is scheduled for launch on March 15 from Pad 39A at KSC.
_____________________________________
Dude, you are so awesome...
Can I be on your ash jump ?
Kevin, you should talk to the people over there, bail the crazy chick out of trouble and use her as a sort of tabloid promotion for NASA operations. For Example: A real life drama involving a shuttle team and their pursuit to gain entry to the next shuttle launch, complete with personal challenges, eliminations, and members voting each other out of the competition.
Come on dude, get with the times!
"I encourage all awesome dangerous behavior." - Jeffro Fincher
This is actually a great shot to show a lot of our International Space Station (ISS) stuff. This is a very large cleanroom, which is in the Space Station Processing Facility. It is about 5 stories high, and kept to strict temp and humidity levels. The air is filtered and kept very clean. Anyone who is working on the flight hardware wears the cleanroom garments, or "bunny suits", to avoid contaminating any components.
In the foreground of the photo, on the right, is the Node 2 module. It is a connection point for other modules, and will be launched in August. On the left is the European Laboratory module, Columbus, which is scheduled for launch in October.
In the photo, the S3/S4 Truss segment is moving down the center of the processing bay toward the Payload Canister, which is at the far end of the photo. The canister is a large container that is the same size as the shuttle payload bay, and has big doors on the top like the shuttle. Once the payload is locked into the canister, the doors are closed and the whole thing is kept at the same temp, humidity, and cleanliness conditions as the cleanroom. Then the big door at the far end is opened for it to go to the pad.
There is a lot of info on the KSC website. The part that shows ISS payloads is here:
http://www.nasa.gov/centers/kennedy/stationpayloads/issprocessing.html
There is also a huge amount of info on shuttle launch. landing and every other thing you could possibly be interested in.
Kevin
Cool thanks. It looked like the Truss track didn't go all the way back to what i thought was the payload canister. ( just trying to help you guys out.);)
May have met you in Deland a few years ago. Would love to work there even if its just a dusting job.
