i've had 2 pilots (188 and 140) and 2 sabres (210 and 170), all different sizes, i have to say that i liked the pilot better, but it kinda depends on where you are wanting to take your canopy flight. the reason i like the pilot is because it works really well at both extremes of flight, fast and slow, i used my 188 for filming CRW and at the same time learned how to swoop under that canopy, the short recovery arc was exactly what i needed to fine tune my skills with a canopy that would help me out in the corner a bit if i did something stupid. the openings on my pilots were way better than my sabre2s and way more on heading.
i think that the pilot is a great canopy for novice jumpers and what i really love about them is that you can load them up a bit and really get some speed out of them. but even at 1.9 under my 140 i found that i had the ability to stay up forever in brakes or on the rears if i needed too, i was still able to film CRW with that one and at the same time take it for 200' on the landings.
i can safely say that if i were looking for a semi-elliptical main right now i would only look one place and that would be the pilot. i think it is definately the best all-around canopy and being a poor college guy its got a great price tag as well
The only bad skydive is your last!
chris "sonic wookie" harwell
Piedra-belluda-roja Rodriguez
After my A License, I made my first 350 jumps on Sabre 2's. I've got my last 300 on various size Pilots and I prefer the openings of my Pilots ten-fold. No complaints about the flight characteristics either!
Katie
Get your PMS glass necklace here
Katie
Chris, Katie
Your guys ROCK!! Thanks for the positive feed back on our products. Good to have you FlyAerodyne.
Blue Skies
Karl Meyer
Sales Representative
Aerodyne Research
Office: 1 813 891 6300
Mobile: 1 813 841 2149
karl@flyaerodyne.com
www.flyaerodyne.com
Blue Skies
Karl Meyer
Aerodyne Research
www.flyaerodyne.com
Bushman, I just lost all respect for you.
Long time ago when you were working for the marketing department at Performance Designs, you said that hybrid canopies were a good idea, by putting ZP on the top skin you get longer lasting canopies, because the ZP is stronger.
The Sabre2 and the pilot are 2 different canopies. Sabre 2 has a steeper glide ratio which makes the wing more stable and you have a wider range of flight characteristics, while the Pilot is a really flat canopy. I have not much experience but if my control range goes from my ears to the middle of my chest then I will take a Sabre 2 where I have a longer control range and the canopy doesn't stall rapidly like the pilot.
Getting back to hybrid canopies, your A2 is Hybrid that you copied from the PD/RWS EZ 384 that is a canopy that gets jumped a lot by most DZs because it is easy to pack and it lasts longer. the Navigator, another hybrid canopy (you know all this you worked at PD) its a great canopy, same characteristics as the EZ384 in packing and life. So the actual question should be made to the DZ operators, the people that buy the canopies for a business.
Bushman, nothing personal, but don't backstab people, you worked for PD so you know more than most people do about materials.
billvon 3,121
I have about 500 jumps on Pilots sized:
210 (a few, just to see what they're like)
168 (same)
150 (bigways and wingsuit jumps)
140 (bigways, now Amy's primary canopy; it's coming up on 1000 jumps/third lineset)
117 (my second rig now)
Out of those several hundred jumps I have never had one "stall rapidly." The larger sizes won't stall at all at my (and Amy's) loading without taking a wrap. You can force them to stall if you try, and they recover like any other canopy. Stall break is a bit less violent than, say, that on a Nitro.
168 (same)
Pilot was nice, very quick turns, similar flight characteristics, great openings. But the safire 2 just seemed better for me. Slightly less zippy but rock solid from pulling the pud to picking it up off the ground once I landed.
