bigway 4 #1 March 17, 2007 That's buggin the shit out of me!! On my canon pixma photo printer the following inks are in the printer. cyan, magneta, yellow, black and another black. So when i print photos of clouds, where does the white ink come from?? I thought maybe it just uses the paper as the white but when rubbing the white ink off then you see the paper. So it is white ink?!? Where does it come from???? .Karnage Krew Gear Store . Quote Share this post Link to post Share on other sites
bigway 4 #2 March 18, 2007 bump, i am still looking for an answer. .Karnage Krew Gear Store . Quote Share this post Link to post Share on other sites
karenmeal 0 #3 March 18, 2007 I have no clue. When mixing colored light you can make white.. But when mixing colored paint you can't get white. Are you sure it was white ink that rubbed off? "Life is a temporary victory over the causes which induce death." - Sylvester Graham Quote Share this post Link to post Share on other sites
d123 4 #4 March 18, 2007 Yes the paper it's white. CMYK are the base colors for printers. RGB are the base colors for monitors. Do a test open Adobe Photoshop make a new white RGB image then convert it to CMYK and look on each channels (CTRL-1,2,3,4). They are all black so this means that the color white has no projection on CMYK base. If the paper is not white CMYK will not work. ... I think Edit to add: It's that for sure. I've made a new test (just for you BIGWAY) with a 60% grey image in RGB Base. The result is 40% on the black channel and 0% in the others channels from the CMYK base . K stands for black Edit some more: This means that the printer colors fades to white when the printer is almost empty and the screen colors fades to black when the screen it's way too old, which is true.Lock, Dock and Two Smoking Barrelrolls! Quote Share this post Link to post Share on other sites
bigway 4 #5 March 18, 2007 QuoteYes the paper it's white. CMYK are the base colors for printers. RGB are the base colors for monitors. Do a test open Adobe Photoshop make a new white RGB image then convert it to CMYK and look on each channels (CTRL-1,2,3,4). They are all black so this means that the color white has no projection on CMYK base. If the paper is not white CMYK will not work. ... I think Edit to add: It's that for sure. I've made a new test (just for you BIGWAY) with a 60% grey image in RGB Base. The result is 40% on the black channel and 0% in the others channels from the CMYK base . K stands for black Edit some more: This means that the printer colors fades to white when the printer is almost empty and the screen colors fades to black when the screen it's way too old, which is true. Anyone else in english please? .Karnage Krew Gear Store . Quote Share this post Link to post Share on other sites
airtwardo 7 #6 March 18, 2007 Anyone else in English please? Quote It's all smoke and mirrors! ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites d123 4 #7 March 18, 2007 Plain english: the white comes from the white paper. If the paper is not white the thing will not work Is that english enough? Don't hesitate to ask for details if you want to delve more into the subject.Lock, Dock and Two Smoking Barrelrolls! Quote Share this post Link to post Share on other sites jkm2500 0 #8 March 18, 2007 If you print on colored paper do you get white?The primary purpose of the Armed Forces is to prepare for and to prevail in combat should the need arise. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
