Blink
Removing Reserve and Cypres?
I just acquired an older rig, and I am looking to take the Reserve and Cypres out, Is it really necessary to have a rigger do it? I am taking the Cypres out to sell, and I will be putting the reserve in another container, so this one will be empty. I've watched reserves be packed, so I have an idea of what is it there.
Thanks!
You shouldn't have had to ask that question, it should have been in the FJC!
So your statement tells me, 1. you were sleeping in class or just not paying attention. Or
2. You instructor just sucked over all and didn't provide the information he should have.
IMHO
you can't pay for kids schoolin' with love of skydiving! ~ Airtwardo
Removing the Cypres is pretty straightforward.
Disassembling a reserve is not difficult, but there are a few things that, done wrong, will create extra work for the rigger who installs/packs it into your new rig. For that reason alone it's a good idea to leave it attached to the container and let your rigger disassemble it when s/he is ready to assemble it into the other container.
But if you really want to do it, here are a few tips. Vacuum/sweep the floor you'll be working on and put the pets in another room. Remember that the links go with the canopy, not with the container. As you remove each link, attach it to a piece of cardboard and mark which riser group it is on the cardboard (this will keep the lines straighter and make your riggers job a bit easier). Don't cut the steering lines to remove the toggles; instead, depending on how they are attached, either untie the knot or slip the toggle back through the loop (toggles go with the container). Tie the steering lines either onto the cardboard or through the rear riser group links. Daisy chain the lines (partly to save room, partly to keep the lines straighter).
