jasonRose 0 #1 October 9, 2006 How do you keep ripstop nylon from puckering when you sew it?? Some day I will have the best staff in the world!!! Quote Share this post Link to post Share on other sites
Calvin19 0 #2 October 9, 2006 as in bunching? lower the tension on your machine and keep tension on the material while sewing. -SPACE- Quote Share this post Link to post Share on other sites
jasonRose 0 #3 October 9, 2006 Thanks for the tip it worked. My machine has a auto tension feature which I use all the time with no problems except when I tried to sew RSN. Took me a little bit to dial in but works great now!! Thanks Some day I will have the best staff in the world!!! Quote Share this post Link to post Share on other sites
riggerrob 644 #4 October 9, 2006 Get a firm grip on the nylon behind the needle and a firm grip (6 or 8 inches) in front. Maintain that same hand spacing as you gently press on the pedal. Move your hands in time with the feed dogs. That will prevent the fabric from bunching. Also, your hands will help feed the fabric because ripstop nylon is too thin for most feed dogs to get a grip. Quote Share this post Link to post Share on other sites
jasonRose 0 #5 October 10, 2006 Ok these are some good tips!!! Thanks for the help. Do you have any tricks to make a french role on RSN any easier?? Some day I will have the best staff in the world!!! Quote Share this post Link to post Share on other sites
aironscott 3 #6 October 10, 2006 You might want to consult your local rigger. Aaron Your local rigger“God Damn Mountain Dew MotherFuckers!” Quote Share this post Link to post Share on other sites
