mjosparky
Questions to ask.
Things to ask/find out BEFORE buying a used rig.
1. Is the harness/container the correct size?
a. Does the harness fit properly?
b. Will the pack trays accept canopies that are the right size for your experience level?
2. Is the system free fly friendly?
a. Riser covers in good shape?
b. Reserve and main pin flaps?
c. Bridle protection?
d. BOC pocket tight?
3. Does the rig have SB’s or need upgrades?
a. Hard housings for cutaway cables.
b. Riser inserts for excess cable.
4. Over all condition of Harness/container system.
a. Old or worn risers.
b. Any stitching frayed or broken, on both harness and container.
c. Excessive dirt or stains.
d. Reserve PC/bridle and freebag the right size and in good shape.
e. Main “D” bag the right one for system and in good shape, any tears, the grommets in good shape and stow band keepers in good shape.
f. Main PC and bridle. Right choice for system, no tears, the right handle for system and check kill line for wear.
g. Will system accept an AAD without modifications?
I am sure I am leaving something out but you get the point. Get all your questions answered before laying down your money. Don’t rush into something your may regret a month later.
Remember you are not buying bowling shoes, make sure it is right.:)
Is it worth making this sort of info sticky or putting it in the gear section?
I know what Sparky says is mainly common sense, but there isn't always a monopoly on that is there.
Good Post
The CLF
The CLF
On break off turn and track as far and as fast as possible....
Because not only your life depends on it but so does mine!!
What''s that? I know what a bridle is ;) but what is the protection meant here?
Older rigs (like mine) sometimes have an inch or two of exposed bridle between the mouth of the BOC and where it tucks up under the closing flaps. Not usually a big deal in FS etc, but if you've left a little slack and/or are reaching high speeds in a sit/ stand there is a higher potential for a premie or horseshoe. Newer rigs have spandex covers or contoured flaps which completely protect the bridle from the airflow.
Do you want to have an ideagasm?
Good stuff! The only things I would add -
If the system is not freefly friendly, what will be the cost of making it so (if that is possible)?
If it is not possible, do I understand and accept the limitations of this equipment and intend to skydive within those limitations?
Excellent add, thank you.:)
