1969912 0 #1 May 16, 2007 On big turbofan engines in use on airliners, is the fan driven by the main engine shaft (through a gearbox?), or does it have its own turbine disk (with the compressor stages driven by a separate turbine)? "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
GrabGrass 0 #2 May 16, 2007 Quote On big turbofan engines in use on airliners, is the fan driven by the main engine shaft (through a gearbox?), or does it have its own turbine disk (with the compressor stages driven by a separate turbine)? Yes. ~ "Pack Fast, Pull Low... and Date Your Riggers WIFE!" ~ Quote Share this post Link to post Share on other sites
1969912 0 #3 May 16, 2007 That was helpful! "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
airtwardo 7 #4 May 16, 2007 Quote That was helpful! http://ctr-sgi1.stanford.edu/CITS/ge90.html Looks like a straight shaft to me... ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
1969912 0 #5 May 16, 2007 Quote Quote That was helpful! http://ctr-sgi1.stanford.edu/CITS/ge90.html Looks like a straight shaft to me... Maybe with its own turbine, otherwise the fan blade tip speeds would be incredibly high if the fan was rotating at the same speed as the compressor section. Any idea how fast the fan section spins? "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
airtwardo 7 #6 May 16, 2007 Quote Any idea how fast the fan section spins? Quote Yes. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
NewGuy2005 53 #7 May 16, 2007 Quote Any idea how fast the fan section spins? Fairly quick, if I'm not mistaken. It "fans" better, the faster it goes, you see. Quote Share this post Link to post Share on other sites
1969912 0 #8 May 16, 2007 Blows "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
airtwardo 7 #9 May 16, 2007 QuoteBlows http://www.turbokart.com/about_ge90.htm Actually on the GE 90 it turns pretty slow...like 2500 rpm. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
2fat2fly 0 #10 May 16, 2007 Think Suck, Bang, BlowI am not the man. But the man knows my name...and he's worried Quote Share this post Link to post Share on other sites
VectorBoy 0 #11 May 16, 2007 Those engines are actually two concentric but counter rotating shafts. Think of a spool within a spool. The big fan on the front is attached to the very last stages of the turbine. I don't have the links but GE has some very cool audio visual clips of their products. Quote Share this post Link to post Share on other sites
1969912 0 #12 May 16, 2007 QuoteQuoteBlows http://www.turbokart.com/about_ge90.htm Actually on the GE 90 it turns pretty slow...like 2500 rpm. Thanks. Looks like the fan is driven through a concentric shaft arrangement by its own turbine. Based on the numbers from the page you cited, fan blade tip speed is ~1400 f/s, but in reality it is probably just subsonic. The pressure ratio is amazing. Air is compressed to ove 600 psi to feed the burners! "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
2fat2fly 0 #13 May 16, 2007 http://www.aircraftenginedesign.com/custom.html4.htmlI am not the man. But the man knows my name...and he's worried Quote Share this post Link to post Share on other sites
1969912 0 #14 May 16, 2007 Quote Those engines are actually two concentric but counter rotating shafts. Think of a spool within a spool. The big fan on the front is attached to the very last stages of the turbine. I don't have the links but GE has some very cool audio visual clips of their products. Are they counter rotating to counteract gyroscopic forces, or is it due to design of the gas flow in the tubines, i.e. using opposite rotation to act kind of like stator blades? "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
2fat2fly 0 #15 May 16, 2007 Go forward, learn http://www.erau.edu/db/degrees/ap_program/ap_cert.htmlI am not the man. But the man knows my name...and he's worried Quote Share this post Link to post Share on other sites
airtwardo 7 #16 May 16, 2007 QuoteThink Suck, Bang, Blow It's suck, bang, squish, blow...as opposed to the -suck squish BANG blow in a 'real' (round) airplane engine! ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
htrammel 0 #17 May 16, 2007 Quote Quote Think Suck, Bang, Blow It's suck, bang, squish, blow...as opposed to the -suck squish BANG blow in a 'real' (round) airplane engine! Nope. It still gets the squish (or squeeze) before it gets the bang. LPC - HPC - Combustor - HPT - LPT Also to the OP: If your profile is correct and you are in Washington, I highly recommend a pilgrimage to the museum at Boeing field (KBFI). Lots of info and just plain neat stuff there. If you ever get to the Hartford, CT area look me up and I'll get you a little tour of Pratt and Whitney. They know a thing or two about engines. Quote Share this post Link to post Share on other sites
akarunway 1 #18 May 16, 2007 Quote On big turbofan engines in use on airliners, is the fan driven by the main engine shaft (through a gearbox?), or does it have its own turbine disk (with the compressor stages driven by a separate turbine)? This might help>http://www.grc.nasa.gov/WWW/K-12/airplane/aturbf.htmlI hold it true, whate'er befall; I feel it, when I sorrow most; 'Tis better to have loved and lost Than never to have loved at all. Quote Share this post Link to post Share on other sites
1969912 0 #19 May 16, 2007 Quote Also to the OP: If your profile is correct and you are in Washington, I highly recommend a pilgrimage to the museum at Boeing field (KBFI). Lots of info and just plain neat stuff there. If you ever get to the Hartford, CT area look me up and I'll get you a little tour of Pratt and Whitney. They know a thing or two about engines. Smile Yep, been to the museum, and thanks for the offer! "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
2fat2fly 0 #20 May 16, 2007 You in Hartford? i think I'll be up for AOPAI am not the man. But the man knows my name...and he's worried Quote Share this post Link to post Share on other sites
billvon 3,126 #21 May 16, 2007 > On big turbofan engines in use on airliners, is the fan driven by the main >engine shaft (through a gearbox?), or does it have its own turbine disk >(with the compressor stages driven by a separate turbine)? Most turbofans have two power turbine stages. One drives the compressor, the other drives the fan. No gearing there. Most turbofans have gearing for power takeoff to run ancillary devices like generators and pumps. Turboshaft/turboprop aircraft have a gearbox that reduces RPM to a speed that's usable with prop engines (2000RPM or so.) Some (like the PT6 line) have a separate turbine to run the compressor and the output shaft; some (like the Garretts) have a single turbine. Quote Share this post Link to post Share on other sites
1969912 0 #22 May 16, 2007 So on a turbofan, what limits the RPM's of the fan? Do they have movable vanes in the tubine section or is the whole thing just designed such that the fan cannot over-rev? "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
airtwardo 7 #23 May 16, 2007 http://en.wikipedia.org/wiki/Compressor_stall ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
htrammel 0 #24 May 17, 2007 QuoteYou in Hartford? i think I'll be up for AOPA Lemme know. We'll have a beverage. Quote Share this post Link to post Share on other sites
