The111 1 #1 June 4, 2007 I have an old Netgear router, the "RT314". When I need to log into it for port forwarding, I go to http://192.168.0.1 with my browser. Right now one of the two PC's on my network will not do that. It comes up as an invalid webpage. Both PC's are using XP and IE7.0, and on the one that doesn't work I just get the generic IE "webpage cannot be found" error. It worked for a long time before now, and I've never seen this before... any ideas what has changed? The computer in question does still have access to the internet and the network.www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
ntrprnr 0 #2 June 4, 2007 Try 192.168.1.1 instead of 192.168.0.1_______________ "Why'd you track away at 7,000 feet?" "Even in freefall, I have commitment issues." Quote Share this post Link to post Share on other sites
unformed 0 #3 June 4, 2007 If that doesn't work, type "ipconfig" in the command line, and go to the address listed as the default gateway.This ad space for sale. Quote Share this post Link to post Share on other sites
The111 1 #4 June 5, 2007 My default gateway is 192.168.0.1. And 192.168.1.1 does not work either. Next idea? www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
pwln 0 #5 June 5, 2007 Find the little reset button, power off your computers, unplug the router, press and hold the reset button AND plug in the router. That "should" reset factory defaults. Power on your computers, then just go in and reset all of your settings. Don't forget to change your password. I assume you've tried https. It is also possible there is a firewall issue on the system that you are having problems with. Try to disable 3rd party firewalls (if XP / vista, windows firewall also). Quote Share this post Link to post Share on other sites
The111 1 #6 June 5, 2007 I will try that, but I am pretty sure the problem is with the PC and not the router.www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
PhreeZone 20 #7 June 5, 2007 Look at your hosts file, some times a nasty piece of spyware will mod it so that IP's reroute to null. What port numbers are you connected to on the router?Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
The111 1 #8 June 5, 2007 Where and what is hosts file? I have ports 1234, 4321, and 2538 reserved for P2P apps which require them. But I don't know if that's what you mean by "connected". I also scan with AVG daily so would hope no spyware slipped through. Guess I haven't run AdAware in a while though... will try that.www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
wildblue 7 #9 June 5, 2007 Have you unplugged/replugged the router? I've never seen spyware hijack the hosts file.... but phree does work for an internet security company (shudder) c:\windows\system32/drivers/etc or c:\winnnt\system32/drivers/etc Is it sad I know that from memory? Now who can tell me about the lmhosts file? it's like incest - you're substituting convenience for quality Quote Share this post Link to post Share on other sites
pwln 0 #10 June 5, 2007 Yeah, what they said. I have not seen it to be a HOSTS file problem myself (But my hosts file gets rid of google ads for me). There is a small chance a newly installed program is causing the problem. It could also be a BHO (Browser Helper Object) There is a way to start IE7 without BHO's but I'm on a work system with IE6 right now. Quote Share this post Link to post Share on other sites
The111 1 #11 June 5, 2007 Well shit, your mention of "BHO's" made me think to try it in Firefox (which I thought for sure I had done before). And lo and behold, it WORKS in Firefox. So have we narrowed it down to IE somehow? I also tried it in IE6 (I have a hacked standalone version I use for web design) and it doesn't work there either... so it seems to be IE in general.www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
IanHarrop 43 #12 June 5, 2007 check your security settings in IE... make sure they are all at the default level"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
The111 1 #13 June 5, 2007 All security settings at default in IE. Even with Windows firewall off, still can't access router from IE. But I can, of course from Firefox. So the problem is now academic, since I have a way of getting into the router. But it still pisses me off.www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
wildblue 7 #14 June 5, 2007 Check your proxy settings in IE. And/or run adware/spyware busting software.it's like incest - you're substituting convenience for quality Quote Share this post Link to post Share on other sites
The111 1 #15 June 6, 2007 Still don't know how to check my hosts file (although I now have the path to it) nor do I know how to check proxy settings (or what they are). I ran spyware checkers and am ok. I also ran Hijackthis, but I have no idea how to interpret these logs. There are several BHO's but they sound ok (see below). I also successfully used IE7.0 on my alternate O/S (Vista) to log into the router. So it is something specific to IE and my XP installation. Logfile of Trend Micro HijackThis v2.0.0 (BETA) Scan saved at 11:50:02 PM, on 6/5/2007 Platform: Windows XP SP2 (WinNT 5.01.2600) Boot mode: Normal Running processes: C:\WINDOWS\System32\smss.exe C:\WINDOWS\system32\winlogon.exe C:\WINDOWS\system32\services.exe C:\WINDOWS\system32\lsass.exe C:\WINDOWS\system32\Ati2evxx.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\system32\Ati2evxx.exe C:\WINDOWS\Explorer.EXE C:\WINDOWS\system32\spoolsv.exe C:\WINDOWS\RTHDCPL.EXE C:\WINDOWS\system32\CTHELPER.EXE C:\AVGFRE~1\avgcc.exe C:\PowerDVD 7\PDVDServ.exe C:\iTunes\iTunesHelper.exe C:\Program Files\Java\jre1.6.0_01\bin\jusched.exe C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe C:\WINDOWS\system32\ctfmon.exe C:\Logitech\SetPoint\SetPoint.exe C:\Program Files\Common Files\Logitech\KHAL\KHALMNPR.EXE C:\EVEREST Ultimate Edition\everest.bin C:\AVGFRE~1\avgamsvr.exe C:\AVGFRE~1\avgupsvc.exe C:\AVGFRE~1\avgemc.exe C:\Dassault Systemes\B16\intel_a\code\bin\CATSysDemon.exe C:\PTC\Pro ENGINEER Wildfire 2.0 M150\flexlm\i486_nt\obj\lmgrd.exe C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe C:\PTC\Pro ENGINEER Wildfire 2.0 M150\flexlm\i486_nt\obj\ptc_d.exe C:\WINDOWS\system32\ircomm2k.exe C:\WINDOWS\system32\PnkBstrA.exe C:\Program Files\CyberLink\Shared Files\RichVideo.exe C:\WINDOWS\system32\svchost.exe C:\Program Files\iPod\bin\iPodService.exe C:\Winamp\Winamp.exe C:\Documents and Settings\Matt Hoover\Desktop\HiJackThis_v2.exe R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157 R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896 R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896 R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157 O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Acrobat 7.0\ActiveX\AcroIEHelper.dll O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\SPYBOT~1\SDHelper.dll O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\2.0.301.5672\swg.dll O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE O4 - HKLM\..\Run: [WINDVDPatch] CTHELPER.EXE O4 - HKLM\..\Run: [UpdReg] C:\WINDOWS\UpdReg.EXE O4 - HKLM\..\Run: [Jet Detection] C:\Creative\SBLive\PROGRAM\ADGJDet.exe O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe O4 - HKLM\..\Run: [AVG7_CC] C:\AVGFRE~1\avgcc.exe /STARTUP O4 - HKLM\..\Run: [Logitech Hardware Abstraction Layer] KHALMNPR.EXE O4 - HKLM\..\Run: [PinnacleDriverCheck] C:\WINDOWS\system32\PSDrvCheck.exe -CheckReg O4 - HKLM\..\Run: [RemoteControl] "C:\PowerDVD 7\PDVDServ.exe" O4 - HKLM\..\Run: [LanguageShortcut] "C:\PowerDVD 7\Language\Language.exe" O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime O4 - HKLM\..\Run: [iTunesHelper] "C:\iTunes\iTunesHelper.exe" O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_01\bin\jusched.exe" O4 - HKLM\..\Run: [OSSelectorReinstall] C:\Program Files\Common Files\Acronis\Acronis Disk Director\oss_reinstall.exe O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe O4 - HKUS\S-1-5-19\..\Run: [AVG7_Run] C:\AVGFRE~1\avgw.exe /RUNONCE (User 'LOCAL SERVICE') O4 - HKUS\S-1-5-20\..\Run: [AVG7_Run] C:\AVGFRE~1\avgw.exe /RUNONCE (User 'NETWORK SERVICE') O4 - HKUS\S-1-5-18\..\Run: [AVG7_Run] C:\AVGFRE~1\avgw.exe /RUNONCE (User 'SYSTEM') O4 - HKUS\.DEFAULT\..\Run: [AVG7_Run] C:\AVGFRE~1\avgw.exe /RUNONCE (User 'Default user') O4 - Startup: Adobe Gamma.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe O4 - Startup: EVEREST Ultimate Edition.lnk = C:\EVEREST Ultimate Edition\everest.exe O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Acrobat 7.0\Reader\reader_sl.exe O4 - Global Startup: Logitech SetPoint.lnk = C:\Logitech\SetPoint\SetPoint.exe O4 - Global Startup: Microsoft Office.lnk = C:\Microsoft Office\Office10\OSA.EXE O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\MICROS~1\Office10\EXCEL.EXE/3000 O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing) O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing) O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204 O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1171698629328 O16 - DPF: {70BA88C8-DAE8-4CE9-92BB-979C4A75F53B} (GSDACtl Class) - http://launch.gamespyarcade.com/software/launch/alaunch.cab O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\AVGFRE~1\avgamsvr.exe O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\AVGFRE~1\avgupsvc.exe O23 - Service: AVG E-mail Scanner (AVGEMS) - GRISOFT, s.r.o. - C:\AVGFRE~1\avgemc.exe O23 - Service: Backbone Service (BBDemon) - Dassault Systemes - C:\Dassault Systemes\B16\intel_a\code\bin\CATSysDemon.exe O23 - Service: FLEXlm server for PTC - Macrovision Corporation - C:\PTC\Pro ENGINEER Wildfire 2.0 M150\flexlm\i486_nt\obj\lmgrd.exe O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe O23 - Service: iPodService - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe O23 - Service: Virtual IR COM Port, Service Program (IrCOMM2kSvc) - Jan Kiszka - C:\WINDOWS\system32\ircomm2k.exe O23 - Service: PnkBstrA - Unknown owner - C:\WINDOWS\system32\PnkBstrA.exe O23 - Service: PnkBstrB - Unknown owner - C:\WINDOWS\system32\PnkBstrB.exe O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exe -- End of file - 7948 byteswww.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
mnealtx 0 #16 June 6, 2007 Something to try, don't know if it will help or not, but won't hurt anything: Start > Run, type cmd, press enter type ipconfig/flushdns, press enter type ipconfig/registerdns, press enter type ipconfig/renew all, press enterMike I love you, Shannon and Jim. POPS 9708 , SCR 14706 Quote Share this post Link to post Share on other sites
Derekbox 0 #17 June 6, 2007 To check your hosts file, open notepad, goto open file and paste this in "c:\windows\system32\drivers\etc\hosts" hit enter (the file is "hosts" and it does not have an extenstion, but for all intensive purposes, it is a texst file). At this point, you may or may not see anything. You may see an entry like this: # [Misc A - Z] 127.0.0.1 a8.net Anything started with # is a note, it is ignored. Now if someone tries to access the domain a8.net then it will automatically be forwarded to the IP 127.0.0.1, where it will get nothing and it will fail to load. Savy geeks have started compiling huge lists of known shit domains and use this trick to block access to them. Sometimes good domains can be added to this list. Also some malicious software may edit or rewrite this list and force page redirects, i.e. you goto www.google.com and end up on www.hotskydiveronmuleaction.com I would open a second text file, save it on your desktop, CUT everything out of your hosts file, save it on the back up, save/close the hosts file and restart. Now if this fixes the problem, well you have another problem (virus/trojan/etc) that edited your hosts file. But more than likely that is not the case (restore, or dont, if you dont know what host files are, and you have them then i would advise *NOT* restoring it). I personally would suspect it is your computer/browser causing the issue. As far as the hijack this log, you need to post it on any one of several forums where some ubergeeks will gladly flash there geekness and analyze it for you. Also if you are on a laptop, generally you should connect directly to the router via cat5, it isnt a huge deal (unless its the problem), but generally speaking, its safer and more reliable. Also, not knowing your router specifically, but more than likely there is a simple way to do a hard reset on the unit that will flush everything and from there you can reprogram the router. Many routers have means to edit the IP address used to access it and resetting the router will reset this to the default IP, the tech manual will answer that... Derek P.S. I love you matt Quote Share this post Link to post Share on other sites
The111 1 #18 June 6, 2007 Derek, I love you too. There is no file called hosts without an extension. There is hosts.ics, and there is nothing inside of it except comments. QuoteAlso, not knowing your router specifically, but more than likely there is a simple way to do a hard reset on the unit that will flush everything and from there you can reprogram the router. I can guarantee you the problem is not in the router. As I've said, I can get into the router using Firefox, OR using IE on my Vista partition... but not IE on the XP install on this machine. So it's something to do with IE specifically.www.WingsuitPhotos.com Quote Share this post Link to post Share on other sites
Derekbox 0 #19 June 6, 2007 the hosts file is a hidden systems file, if you type in *.* in the directory, you should see it... Quote Share this post Link to post Share on other sites
virgin-burner 1 #20 June 6, 2007 open your explorer, go tools/internet options/advanced and search for the entry http. tick all of it. i've had the same problem, and as far as i can remember, that did the trick..“Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
wildblue 7 #21 June 6, 2007 Do you have a 'reset web settings' under tools menu in IE? If not Tools | Internet Options | Connections tab | LAN settings button - there shouldn't be anything there. You can get to other websites, right? Just not the router config?it's like incest - you're substituting convenience for quality Quote Share this post Link to post Share on other sites
