dweeb 0 #1 August 21, 2006 Hey there. New to the sport and I'm looking for recommendations on goggles that can accommodate prescription lenses. I'm currently considering The Phoenix because of the ability to change lenses, but I also find Sport RX's G102 goggles appealing. Can anyone help a cherry out? Thanks! Quote Share this post Link to post Share on other sites
beowulf 1 #2 August 22, 2006 I have the G117. It has worked great for the last year or so. Quote Share this post Link to post Share on other sites
dweeb 0 #3 August 22, 2006 Do you have clear lenses or tinted? How does that work for you? Quote Share this post Link to post Share on other sites
xlh883 0 #4 August 22, 2006 I have the Adidas Climacool from SportRX. Works good in the air and on the ground on the Harley. THey come with a headstrap if needed, and only needed for use in a wind tunnel I have found. They work good skydiving with a helmet on, never tried without. David Quote Share this post Link to post Share on other sites
beowulf 1 #5 August 22, 2006 I have the clear lenses so that I could make use of them on night jumps. The frame doesn't seem to hold up all that well to the stresses of skydiving. I have broken one frame and just about finished with my second frame. But since the frames are cheap I will just buy another set of frames and keep the lenses. Quote Share this post Link to post Share on other sites
chanti 0 #6 August 22, 2006 Ask your optometrist. In my practise I keep catalogues of sport eyewear and have been able to help not only skydivers, but bikers, cyclists, golfers, climbers, etc etc. -Chanti- Quote Share this post Link to post Share on other sites
chutem 0 #7 August 23, 2006 If you have a high + perscription make sure you get some that the lenses fairly flat/straight accross from side to side, not wrap around. I got some (can't remember the brand) from e-bay, had lenses made for the inserts, and found out I could not see for S**t straight ahead. The low profile wrap around style caused the lenses to be at to much angle in front of my eyes. I have a very strong prescription so this is probably not a problem for most.(+6 both eyes) I'm at eloy most mondays if anyone in AZ wanted to look at them. I think they were birdz rx but not sure. James Quote Share this post Link to post Share on other sites
