Ronaldo 0 #1 August 1, 2006 Hi, Does anybody know where I can order stainless steel slider grommets (small quantity)? Safe skies RonaldoEngineering Law #5: The most vital dimension on any plan drawing stands the most chance of being omitted Quote Share this post Link to post Share on other sites
ZigZagMarquis 9 #2 August 1, 2006 Para Gear? Don't know what their shipping will be like to Brazil though... Quote Share this post Link to post Share on other sites
Ronaldo 0 #3 August 1, 2006 Tried that, but it seems like they have only small dia grommets. Shipping is not a problem, I've bought from Para-gear a couple of times. Customs is the real problem ThanksEngineering Law #5: The most vital dimension on any plan drawing stands the most chance of being omitted Quote Share this post Link to post Share on other sites
masterrig 1 #4 August 1, 2006 I've never seen #8-SS-grommets in Para-Gear. You might check with one of the parachute manufacturer's and see if, they'll sell you some. Try also, DJ & Associates. Fantastic folks to deal with. Chuck Quote Share this post Link to post Share on other sites
Ronaldo 0 #5 August 1, 2006 Good idea, I guess canopy manufacturers will be the best option. BTW, thanks for the DJ & Associates link. I didn't know that one, very good source of supplies.Engineering Law #5: The most vital dimension on any plan drawing stands the most chance of being omitted Quote Share this post Link to post Share on other sites
masterrig 1 #6 August 1, 2006 You're welcome. The really good thing about DJ & Associates is, they fill small orders and their products are top of the line. Manufacturers are very helpful in regard to selling to 'the public'. I've ordered materials from them for repairs and their prices are good, also. Good luck to you! Chuck Quote Share this post Link to post Share on other sites
riggerrob 644 #7 August 1, 2006 Why do you want stainless steel grommets? SS grommets have fallen out of fashion since soft connector links (i.e. PD Slinks) were introduced. Now that we no longer have to worry about metal banging against metal, brass slider grommets are back in fashion. Besides, stainless steel grommets require very strong/large/expensive presses to install. Quote Share this post Link to post Share on other sites
masterrigger1 2 #8 August 1, 2006 Rob, SS grommets are required for Vectran lines. Vectran lines will saw right throught the soft brass ones and destroy the line set along with the grommets. Try Challenge Sailcloth on the East coast. You will need a 20 ton hydraulic press, the die set and 25 mm rings(grommets). I buy my stock from them. BS, MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites
Waldschrat 0 #9 August 1, 2006 Quote Try Challenge Sailcloth on the East coast. You will need a 20 ton hydraulic press, the die set and 25 mm rings(grommets). Rofl Quote Share this post Link to post Share on other sites
Ronaldo 0 #10 August 2, 2006 Thanks Mel, you’re right, I need ss grommets because I may reline my Cobalt with Vectran in a near future. I just did an h-mod on it to fix some opening issues, so far it seems to be working well but I still have an Xfire on the closet in case I get another slammer. Although I can have access to a large press and die set I’m starting to think it would be much simpler to order one. BTW, could you install these grommets for me? Is it possible to replace the original ones instead of making a new slider? Safe skiesEngineering Law #5: The most vital dimension on any plan drawing stands the most chance of being omitted Quote Share this post Link to post Share on other sites
masterrigger1 2 #11 August 2, 2006 Quote Although I can have access to a large press and die set I’m starting to think it would be much simpler to order one. BTW, could you install these grommets for me? Is it possible to replace the original ones instead of making a new slider? Ronaldo, We can remove the brass ones and install SS with no problem. Just let me know if we can help you. Thanks, MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites
riggerrob 644 #12 August 2, 2006 Are you saying that Vectran is as abrasive as Kevlar? How abrasive is HMA? Quote Share this post Link to post Share on other sites
ZigZagMarquis 9 #13 August 2, 2006 QuoteAre you saying that Vectran is as abrasive as Kevlar? How abrasive is HMA? Ya know, reading on Spectra, Dacron, Vectran, Kevlar and HMAs at places like... http://www.fibersource.com/f-tutor/prods.htm I have a tough time understanding the difference between an HMA and Kevlar... they both seem to be "Aramids", but not quite the same thing? Anyway, I didn't think the problem with Kevlar was that it is abrasive, but rather that it is suseptable to abrasives? ... i.e. when used as suspension lines on parachutes, Kevlar doesn't play nice with the sand and grit it encouters on "landing", "packing", etc. Quote Share this post Link to post Share on other sites
masterrigger1 2 #14 August 2, 2006 Rob, I do not have any thing to compare with in the Kevlar end of things. The only canopies I have dealt with Kevlar lines are reserves and they are not used enough to see if they are wearing the grommets. The earlier "course' braided Vectran was extremely abrasive to brass grommets. BS, MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites
Ronaldo 0 #15 August 3, 2006 QuoteAre you saying that Vectran is as abrasive as Kevlar? How abrasive is HMA? I was also curious so I did a quick test rubbing a piece of Vectran line against a brass grommet to see if there was really a possibility of damage. It took only a few seconds to see the marks inside the grommet.Engineering Law #5: The most vital dimension on any plan drawing stands the most chance of being omitted Quote Share this post Link to post Share on other sites
