azdiver
what should i do
i have a 94 chevy 3/4 ton truck its a work truck. has a 410 rear end and a 454 big block. it gets 8 miles to the gallon and im driving alot. i can either replace the engine with a 350 and the rear end gears to a 373 or buy a new truck. a new truck is only going to beat to hell were as this one already is. old truck has 220k miles blue book value roughly 2k
cost
new truck at least 20k
replacement parts 2500
light travels faster than sound, that's why some people appear to be bright until you hear them speak
the mechanics of the truck are in decent shape the body is a ding scratched and dented though, but in construction you except that that will eventually happen
depends.. i voted replace the failed parts but...
do you expect the same work load as the old truck took? What are the chances of something else major failing on the old truck that might be covered by warrantee on a new? Do you like doing all the work to replace the rear end and engine? You have to factor your labor into the cost even if you arent 'paying yourself'. Then attempt to figure how much time 'out' you will have if/when something else fails and you have to replace it.
You (should) get better mileage out of a new one so that should factor into reduced cost over the long term.
basically in my view its
1.Keep old truck and eat the additional costs and labor when it breaks again.
2. Get new truck and eat the purchase costs but have the dealer cover future maintenance while the warrantee is good.
so which do you prefer? giving up money now or time later?
____________________________________
Those who fail to learn from the past are simply Doomed.
engine and rear end are original
Go ahead and replace them. Probably get you an additional 100K miles, and it'd be well worth it. My dad did the same thing with his truck.
"Mediocre people don't like high achievers, and high achievers don't like mediocre people." - SIX TIME National Champion coach Nick Saban
im not hauling around a lot of heavy materials, i just have a lot of tools that have be carried around all the time so its not a huge work load on the truck. as for your point on warranty on a new truck vs time, money in the future is what im still trying to decide
