skydivex3m
loose fabric on vector 3 main flaps..
when I look at my vector 3, the fabric on the left and right flaps up around the second riser cover is all loose.. specially on the sidewalls if you know what I mean.. how do I avoid this.. it dosen't look nice[:/]
https://icarusanddaedalusadventures.blogspot.com/
the container is a V248 from 98, and the main is a sabre 150, the reserve is techno 155.. shuld fit ok.. just tried to make the loop a little smaller.. did not work... any other ideas??
Obviously, I'm not a rigger... :P;) ...so take any advice I give with several large grains of salt!! Have you asked your rigger what he thinks the problem might be?
What I wrote above was what came to my mind when you described the problem. I could see where either too tight or too loose could "wrinkle up". I think I recall seeing a post where someone mentioned having too much bulk in the bottom of the reserve tray could cause it, as well.
Hopefully the riggers will come in and be able to give you an answer... good luck!!
Mike
I love you, Shannon and Jim.
POPS 9708 , SCR 14706
I have a vector 3 that has many jumps on it, after i pack it usually has a few wrinkles on the 2 side flaps, what i do is bend the rig over my knee a bit with the back pad on my knee i push down holding the yoke and the bottom of the container. this makes it all nice and smooth! the reserve packjob has alot to do wit it too, my rigger has the same container so he knows it inside and out!!
hope that helps?
"When the power of love overcomes the love of power, then the world will see peace." - 'Jimi' Hendrix
I tried that too just now.. It helped a bit, but not enough at all.. there are not many vector 3's in Denmark yet, and I don't think my rigger is so familiar with it..
does anyone have a few tips to a good reserve pack result?? anything that could prevent this wrinkels??
Silly question... are you closing the main flaps in the correct order? ... Bottom (yeah, I know that's where the main closing loop is on a V3)... Top... Right... Left... and not Left... Right??
Anyway... looking in the V3 manual, there's pictures of V3's with a few wrinkles in the area you describe / it looks like what you describe... sounds to be a cosmetic problem and probably really to worry about.
... as for Reserve Packing Tips... read the manual, also, check this (see encl)...
yeah.. I close the right way.. I have alså seen the manual, and the wrinkels on the pictures are not half as bad as the ones on mine.. I'm just getting tired of looking at it.. thats all.. It is just cosmetic, but means a lot to me anyway..
thatks for the tips..
If you have a 348 it is sized for a 170 main and a 160-170 reserve. The Techno packs smaller them the PD160R that is recommended for that size rig. You are basically under filling both halfs and the wrinkles are a result.
Yesterday is history
And tomorrow is a mystery
Parachutemanuals.com
Did they supply you with the correct main deployment bag? unfortunatly there is no real way to tell. Try packing your canopy without a bag (for ground testing ONLY!!!), if it fills the container to your desires then ask for a new deployment bag, if that doesn't work have a custom bag made 1" wider. That usually does the trick. Asthetics are the last thing on a H/C container engineers mind as he "scales up", that stuff comes later down the road. That is the way it works.
Mick.
Sometimes those wrinkles sneak in during the sewing process and there is nothing you can do about the after the fact.
For example, one of my clients is very fussy about his gear. Unfortunately, his Vector 3 has a little bit of seam puckering where the internal riser covers are sewn to the reserve container.
He has asked me a dozen times to smooth them out, but I cannot do that without building an entirely new reserve container.
Funny how the Uninsured Relative Workshop won't loan me their patterns????
Hee!
Hee!
the D-bag is the correct size.. I will try to get a more experienced packer to do the reserve in a cuple of weeks when it is time again... thanks for the tips everyone..
It's also not outside the realm of possability that the bag has the wromg stamp on it, it does happen from time to time. They only way to know for sure is to measure it and compare it with eithier RWS measurments or bag of the same size from another same size rig.
Mick.
