Pablito
Vigil and Vehicles
FYI, this could be for all AADs to.
17. What happens if I forgot to shut down my Vigil when I travel in a moving vehicle (Train, Car, Bus...) ?
Vigil is the most accurate AAD on the market. It becomes operational in a zone of 150ft/46m above or under takeoff level. To avoid unexpected firing, you must switch OFF your Vigil before traveling in a closed vehicle (boot or trunk) due to possible air pressure variation.
Cielos Azules
Pablito
"If you don't overcome your fears they will overcome you first"
Shady Monkey/6Segundos Rodriguez/AKA Pablito
Well if you are driving and you are going downhill and there is a storm approaching, the chances are slim but it could happen.
If the unit is on and you slam the door of your car and is a tight seal car, it also could happen
Cielos Azules
Pablito
The +150 feet can be inferred from section 4, "Flight Restriction for the Pilot." if there is an extended time (100 seconds) within that window, Vigil assumes a change in surface pressure, not altitude. 100 seconds should be plenty of time for all but the slowest jump planes to climb at least 150 feet.
Mark
Page 17:)
The Vigil is now ready for use and is in a stand-by status (recalibrating itself every 32 sec).
During take off the Vigil will go to an active status (64 calculations per sec.) above 150
feet or under -150 feet (+ 46 m or – 46 m) in a time of max. 32 sec.
Vigil’s active status will be confirmed by three short flashings of the green led.
"Buttons aren't toys." - Trillian
Ken
Thank you. I have the older version of the manual 2.0.2, and it does not have that.:)
The quote was from version 2.0.7; downloaded from AAD's website. I wonder how many versions/ revisions they've gone thru in the past few years?
Ken
