shropshire
Collapsible Slider
:$I cann't reach it (short arms) and it's constant flapping is bugging me. Should I ask my rigger to put on shorter risers? If so, how will this affect the canopy handling (if at all)?
Ta,
(.)Y(.)
Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome
hey look. a whole bunch of search results. Im not gonna read through them all before asking this.
Do you have some type of slider stop?
I know my slider stops just above my toggles and front dive loops.
Do you have standard or 'mini' risers? if you have standard and switch to mini, then maybe your slider will come down far enough.
good luck.
Goddam dirty hippies piss me off! ~GFD
"What do I get for closing your rig?" ~ me
"Anything you want." ~ female skydiver
Mohoso Rodriguez #865
Good questions, thanks (I'm ashamed to say I dont know all of the answers, without pulling the pin on my rig)..... I know I have slinks and [think] that the slider comes over them.
I'm amazing myself that I jump kit that I'm not fully aware of.... [worried look comes over face]
(.)Y(.)
Ta,
hey the general consensus is that you should have the longest risers that make it so you can reach the slider.
I myself fly 24" risers
I have flown:
18's which resulted in a faster turn, you get out from under your canopy faster, and has a shorter recovery arc.
20's a little slower on the turn stil dives quickly and has a medium recovery arc.
24's have to wail on it to get out from under the canopy and a long recovery arc.
basically the risers put you further or closer away from your canopy changing the radius of the turns that you do. so if you are further away, the circumference is larger so the turn is a wider turn...
closer the circumference is tighter....
(a simple look at it there is mroe to all this)
Cheers
Dave
http://www.skyjunky.com
CSpenceFLY - I can't believe the number of people willing to bet their life on someone else doing the right thing.
Ta,
Have you tried flaring with the back risers before releasing the brakes? Often it brings the slider further down. OR Make sure there is no parachutes around/near or below you, then pull one riser down and grab slider with the other hand.
Some dream of flying, i live the dream...
*John Wayne voice* You makin' funnome pilgrim? *John Wayne voice*
nope. you wanna make sumptin of it?
:D
:D
*John Wayne Voice* Draw! *John Wayne Voice*
Peej pulls his water pistol and gets Hippie with a good squirt before running off to the bonfire :D
Advertisio Rodriguez / Sky
