BKR
Riser cover plastic
Hi Everybody,
I have to repair several old Javelins which have plastic of risers cover broken. Is somebody knows what kind of plastic must be used and where to get it.
Thank you for your answers
Jérôme Bunker
Basik Air Concept
www.basik.fr
http://www.facebook.com/pages/Le-Luc-France/BASIK-AIR-CONCEPT/172133350468
Hi Everybody,
Have you tried the manufacture?
Not yet because US---France, not the best.
So, if I can have the reference or type this will help me better.
Jérôme Bunker
Basik Air Concept
www.basik.fr
Hey there,
I build base rigs with tuck tab riser covers and have tried many different types and thickness of material. The easiest to work with and best combination of stiffness and flexibility is .040 thick Lexan. Lexan is the brand name of polycarbonate, and a plastics distributor should carry it in stock. You can cut it with good scissors and sew through it with any commerical machine.
Cya
I use molybdenum disulfide (MDS) plastic in 20 thou, 30 and 40 thou for container repairs.
20 thou works best for light weight tuck tabs (i.e. riser covers).
30 thou is used for stuff like kicker plates, while 40 thou works best for high tension components like pack tray stiffeners and main side flaps.
When in doubt, use the same thickness as the original manufacturer.
That old-school, white nylatron only works at soft pack densities (i.e pilot emergency back packs).
Lexan just cracks too easily, ergo I only use Lexan on quick-replace components like the Velcro-attached reserve top flap on Student NAROs.
Oh!
And invest in the biggest, baddest, double-needle binder you can find.
