2jumphi
Cypres Loops
I have looked in the cypres manuals and have not found anything.
Because there isn't anything -- it's condition, not time. it's your call, just like when to replace a Type IIA closing loop.
For a technical reference, all I could find was the Parachute Rigger Handbook, FAA-H-8083-17, which says on page 5-10, "Many riggers simply replace the loops at each repack, regardless of the condition," implying there is no standard for how often to change it.
Mark
Every repack for 1-pin rigs and every other for 2-pin rigs (racer etc)
I believe that it is especially important for anyone that is using a positive leverage device to close the rig to change them EVERY repack due to the forces that can be exerted during closing.
just my tuppence worth
I like my canopy...
...it lets me down.
The original post asked for technical info, that is, a reference. I agree with your practice, but am wondering if you could cite a manual or regulation.
Mark
Hi koppel,
Re: 'due to the forces that can be exerted'
This REPLY is not to be negative towards you in any manner. Just wondering about your (and other's) thinking regarding the forces applied to the Locking Loop when using or not using a positive leverage device.
IMO there is a thinking that if one does not use a positive leverage device then just pull to your hearts content. I disagree with this thinking. IMO it comes down to just what forces are actually applied to the Locking Loop, not the method of applying those forces.
Lots of riggers use lots of devices and, I will argue, that they do not know the forces that they are applying to the Locking Loop.
I personally witnessed a very good friend break a quite new Locking Loop by pulling on the pull-up cord by hand (yes, he was and is a very strong person). Therefore, I contend that it is not the device that is used, it is the actual force that is applied. I do however agree that it is very much easier to apply large forces with the positive leverage device, but I do not agree that it applies more force than other methods.
Riggerrob has posted about using a strap with a hook from a harness snap with the strap around his body/shoulders. I think that is a great device; but does he know how much force he is applying? Does anyone?
Just my old $0.02 which isn't much sometimes.
Jerry
Hi koppel,
Jerry
I agree, the loop does not know how the force is applied. Regardless of how it is applied you need enough force to get the loop through the bag, the P/C and all the flaps far enough to put the pin in. As in any rigging task care needs to be taken.
Good Point and well made. Thank you.
you are correct that the loop does not know where the force comes from.
on the subject of "quite new Locking loop' are you talking about a Main or Reserve? If it is a Reserve the quote suggests that it was not new. Could that be interpreted to suggest that it is therefore a good idea regardless to change the loop everytime?
Regards
I like my canopy...
...it lets me down.
Jerry
When using a packing hook, I have a very clear indication of how much slack remains. More than 1/2 inch of slack means opening the reserve and shortening the loop.
If I try closing a rig that has no slack/is more than "solid", it is a supreme struggle to close with my packing hook and ripcord pull forces exceed 22 pounds (10 kilograms).
Maybe that "feel" just comes from packing 3,000 reserves with the same tool.
I use the same criterian as for reserve suspension lines: one broken strand.
For clarification... do you consider "one broken stand" acceptable or reason to replace?
I also replace a lot of fuzzy Cypres loops out of pride/fussiness/perfectionism.
As I do as well... what I don't know is why I fairly regularly end up with fuzzy's... Any ideas what causes this?
J
Always remember that some clouds are harder than others...
That happened to me sometimes before I switched to a new temp pin. The old one had some scratches on it and sometimes damaged the loop. The loop looked fine first but started to fray after a while. Drove me crazy until I found out what the problem was.
/D
Hi koppel,
Re: 'If it is a Reserve the quote suggests that it was not new.'
This occurred during drop testing for TSO testing. We had put maybe 3-4-5 tests on the rig; we were just 'jamming' the round canopies into the container (being in a hurry to get things done); Mick was doing the closing of the test container using a plate, a pull-up cord and his hand/arm muscles; and, yes, he broke the Type II sheathing.
As I posted, he was and is a very strong person. It can be done (surely not with every type of Locking Loop) because I watched it happen.
Hi Riggerrob,
Excellent clarification and that does help a lot of people know just how it should be done.
One device that helps eliminate wear/fuzziness/etc on Locking Loops is the stainless steel device that Para-Gear sells that lets you put it through the Locking Loop and then put the ripcord pin into the end of this s/s gizmo, then push the ripcord pin into the Locking Loop (which pushes the gizmo out of the Locking Loop). This gizmo has a smaller end than a ripcord pin so it goes through the loop without damage (is you use it correctly).
I replace ANY loop that shows ANY signs of wear; you do factor loop replacement into your repack charges don't you?
Jerry
PS) A quiz: Who posts here that makes the s/s gizmo for Para-Gear?
I remember reading somewhere (probably PPM) that for main closing loops, when it is frayed 10% of it's total thickness, replace it. That way it never gets to less than 90% of it's total strength.
I do not remember ever reading anything on reserve closing loops. I replace them every re-pack just in case.
Derek
Here is the one I have been using for about 4 or 5 years. I got it from Bob Celeya a DPRE from Cal City.
