alexey
Hot glue on webbing - how to remove?
Place an absorbent cloth over it and iron the cloth on a medium setting. It should soften and absorb into the cloth.
Try to spot check the heat setting on a spare piece of webbing first so you don't damage it.
Peace and Blue Skies!
Bonnie ==>Gravity Gear!
In you have to resew harness, and need to remove old hot glue (cosmetic issues) - how can you do that?
We used to use isopropol rubbing alcohol and a tooth brush, it worked well. It also helped close up the old "bullet holes" and make the repair/ adjustment look almost new.
Mick.
