Stevehend15 0 #1 April 28, 2006 I just bought a used Javelin rig yesterday. I am a little unsure of the fit..... Any suggestions on what to look for? Is it a big deal that the container slides up my back a few inches. I can barley fit my fist between my shoulder and the harness when it is on. I also have the leg straps as tight as they go and feels very tight on me when I do so. Quote Share this post Link to post Share on other sites
wmw999 2,587 #2 April 28, 2006 Take it to the dropzone tommorrow; don't expect to jump it until you've spent a good while with an experienced instructor, experienced rigger, or someone like that to check that kind of thing. How you adjust it can matter; how you put it on, all kinds of things. Being able to get your fist in between your harness and shoulders doesn't sound really good to me, but I'm not seeing just how you're doing it, or how big you are, or how hard you have to try. You really, really want to have a real person involved in this. Tonight, get to know your rig; how it's put together, how the mechanical pieces work, where the strength and stress points are. Then tommorrow you'll be more ready for the fitting session. Don't be in a hurry. It might be that it fits perfectly, it might be that it doesn't, and it might be just that it's OK but not perfect. That's where having someone work with you on it will make a difference. Wendy W.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
Stevehend15 0 #3 April 28, 2006 Thank you... I plan on having the reserve repacked, the main aired out. I also need to do some practice throws on a creeper..... I am definatley not going to jump it until my rigger gives me the go ahead. If I were going to make alterations is it something that my rigger can do or do I have to send it to sun path? I think the only problem is the distance between my leg pads and the top of my harness. Quote Share this post Link to post Share on other sites
wmw999 2,587 #4 April 28, 2006 That's why looking at it in person makes a difference. It could be that it's too long; that's not something that your local rigger can do unless they're a master rigger with the right harness machine and enough practice doing it that you'd trust them with it. But really -- don't unpack the reserve or the main until you've gone through the whole fit thing with someone tommorrow. Wendy W.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
Stevehend15 0 #5 April 28, 2006 Thank you again..... I am going to the DZ bright and early and if it is too big I am going to fix it because I like this rig way too much to send it back! Quote Share this post Link to post Share on other sites
Stevehend15 0 #7 April 28, 2006 I wish I could..... I can try my best to describe the fit though..... The chest strap is long but i loop it back and can stow it with no chance of coming loose.... The leg straps are as tight as I can make them and they feel VERY snug on my legs... The spot where all the leg webbing meets is at my belt line roughly.... The problem as I see it is the shoulder harness. I can fit a fist between my shoulder and the pad and when I lift it I get no seperation from my shoulder. When I did this squat thing with the container on the edge of my bed the container moved up on my back to the point where the three ring was just below my ears. I leaned my body of the edge of my bed and the container slid a few inches up my back. When I tighten the chest strap its impossible for me to squirm my way out of the harness (I tried alot). Hmmmmm.... Anything else that would be important? I have very good flexibility in the harness and its comfortable on me, hopefully not because its too big. Quote Share this post Link to post Share on other sites
jimmytavino 16 #8 April 28, 2006 you need to be considerate of how MUCH the container moves UPwards on you... It will affect where your main pilot chute handle winds up at deployment alt., and could make for an awkward pull. ..IF the 3 rings are waaay up , near your ears,, as you say...will you even be able to reach your toggles,,, and slider?? Try it out from a suspended harness set-up at the dz. I once had Javelin resize a harness for me and they did a great job... good luck.. Quote Share this post Link to post Share on other sites riggerrob 643 #9 April 29, 2006 Jeez! I never tried that bed test. First of all, you can only accurately measure a harness while the canopies are still packed. So leave the canopies inside the container until your rigger has checked how it fits on you. Far more accurate to suspend your Javelin from risers. Alternately, ask the tallest and strongest guy on your DZ to lift you off the floor. Expect to have a 3 or 4 finger-wide gap between your shoulder and the shoulder pad. Quote Share this post Link to post Share on other sites Stevehend15 0 #10 April 29, 2006 hahahahaa, its not a good test.... i got my dad to lift me with the risers and canopy out. I think i fits good, maybe a 2 finger gap. Quote Share this post Link to post Share on other sites mjosparky 4 #11 April 29, 2006 Steve, I am not sure, but aren’t these questions you should have asked before you bought the rig? My idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites Stevehend15 0 #12 April 29, 2006 i know..... he said it would fit and sun path said it would fit....... it could be that im a stupid newbie that doesnt know my head from my ass. i am going to have it fully inspected tomarrow at the DZ and the reserve repacked to be on the safe side. Quote Share this post Link to post Share on other sites mjosparky 4 #13 April 30, 2006 Quoteit could be that im a stupid newbie that doesnt know my head from my ass. Don't consider your self stupid because you are "newbie". We are all newbies to some extent. Just keep in mind before money exchanges hands get all your questions answered.My idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
