woodpecker
any programmers know LMC??
Here is what I have so far. I just cant figure out the LMC code for the gaps I have. I'm trying to input information and have it stored in consecutive mailboxes every input, when 999 is input the program runs. (Basically writing a program loader)
88 INP 901 ; input a value
89 SUB 97 297 ; subtract 999
90 BRZ 01 701 ; done loading, jump to 01 for execution
91 ADD 97 197 ; Restored the instruction by adding 999 back to the calculator
92 STO 01 301 ; store to 01, 02, 03, and so on
93 LDA 92 592 ; load the store instruction’s current value to calculator
94 … ; increment value in calculator by 1
95 … ; modify the store instruction in 92
96 … ; jump back to get another instruction from in basket
97 DAT 999 999 ; value 999 for testing
98 DAT 001 001 ; value 1 for incrementing store index
SONIC WOODY #146
There is a fine line between cockiness and confidence -- which side of the line are you on?
LOOP : INPUT // input into acc
STORE temp // Save to temp location
SUB sentinel // check to see if 999
BZ start // YES so goto START
LOAD temp // get the number back from temp
STORE *location // save to mailbox saved in location
ADD one // increment the location pointer
STORE location // save the location pointer
BR loop // get the next input
HALT // end of program
//DATA
one DAT 01 //constant 1
sentinel DAT 999 //constant 999
//VARIBLES
temp DAT //temprary store
location DAT 01 // location pointer, starts as 1
Actually, you should also put a check into ensure that you dont input too many values or you will walk all over your original code and data..
(.)Y(.)
Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome
