Scoop
Questions about my Wings container
OK, its not got any canopies in it yet and obviously that will effect things slightly but having stuffed it with assorted stuff to pack it out I have few questions about the harness.
PIC 1 - Hip ring location. Now it feels fine and comfortable but looks little high and reaching for the PC it feels slightly higher than I'm used to. My hip bone is actually under the V shaped part of the leg strap. Is this a trademark wings thing or could it be slightly too short. If needs adjusting I guess thats a back to manufacturer thing is it?
PIC 2 - The RSL attachment to risers looks quite cluttered. Is it sitting as it should? All seems to be routed out of the way nicely. Maybe I'm just not use to seeing this type of attachment.
PIC 3 - Ridiculously long chest strap. (sorry for my poor aim with camera) Is this just a case of getting local rigger to shorten it?
Thanks people! Oh and no doubt when I have my rig fully assembled with canopies AAD etc my rigger will inspect it all and advise me too. Just wondered what your opinions were. Thanks :)
Having the chest strap shortened is easy, BUT don't do anything until the rig is completely filled out (with canopies) and you have jumped it for a while. You may find a reason to keep the extra. And making it longer is much harder than shortening it (or leaving it along).
Just my $.02
J
Always remember that some clouds are harder than others...
You are going to loosen that chest strap when it has canopies and perhaps pull down the leg straps. It's a bit hard to tell without the reserve in there.
The canopies will pull the rig up over your back more and it will sit slightly lower on your butt.
You may have to shorten your chest strap a bit, but most people like to loosen them up under canopy. I like mine a bit long for that reason.
The RSL looks clean to me.
I would say pack it up. But if you are not saticfied with the fit at that point contact your dealer before you jump it.
Peace and Blue Skies!
Bonnie ==>Gravity Gear!
Firstly .....I forgive you for copying my colour scheme ...;)
I found the same.....hip rings 'slightly' higher than you would expect.....I spoke with others who said the same....its the design of the container and just takes a bit to get used to.....on the positive side it 'aids' holding the holding the rig tighter to your body......therefore not so much movement of the container on your back during (particularly) freeflying.
RSL looks like an RSL.....whats your concern here...?
Chest strap looks fine.....just fold the excess and stow under a bungee.......
As you explore canopy flight more....you will want to 'adjust' your chest strap after opening....helping to spread the risers and giving the canopy a more efficient flying shape....
Nice rig.....flying this weekend....?
Darren... Well I bought your old jumpsuit so I had to get gear to match. By the way its sporting some mighty fine grass stains at the moment.. Thank god for the padded knees and arse! :P:$
Sadly not. Funds are tight as been out of work *cue violins* and haven't renewed my criminally priced BPA membership. Might go down the DZ with my camera if weathers nice though and get some landing shots. Got new lens for my birthday! :DB|
EDIT: I've seen your vids too, you'll really hate me when you see my helmet. Haha
eeeek....well just dont start stalking me or I will have to call the police.......
hang on...police....you.....:|
Let me know when you are jumping again......lets go do something !
Matching rigs , jumpsuits and helmets........it'll look like a team...:D
Pic 1 - It's referred to as a "hip ring," but it's an articulated harness based on your measurements and the ring is not necessarily on your hip. Please look at the heads down picture on the skydivewings page where his articulation ring is placed. http://www.skydivewings.com/products.htm
Pic 2 - RSL's Fine
Pic 3 - Chest strap looks perfect.
Like others have said, fill it up first, then check it out.
Nobody has time to listen; because they're desperately chasing the need of being heard.
1. The geometry of the Wings harness is a little different from other mfgs. It is a little higher and more forward than some, but this makes for an extremely comfortable rig under canopy.
2. RSL looks clean. Keep in mind there must be enough slack present so that when you are saddled under canopy the main risers do not pull it off the velcro in the lanyard's channel. Furthermore, you do not want it under anything on the rig that it could hangup on in a cutaway.
3.The chest strap is long because many jumpers loosen it under canopy (with the slider collapsed behind head) to flatten the canopy out more and make it fly better. You will learn more about this as you progress.
Enjoy your new Wings, Hixxx
death,as men call him, ends what they call men
-but beauty is more now than dying’s when
PIC 1 - "Hip ring" is a bit of a misnomer. Sandy Reid's (the guy who holds patents on ringed harnesses) formula has the "hip ring" covering the iliac crest (upper edge of your pelvis).
Wings' harness formula mounts those rings slightly higher.
PIC 2 - RSLs are supposed to have a little slack where they attach to risers.
PIC 3 - extra long chest straps are fashionable these days.
From the pictures, everything looks good! As for the 'long' chest strap, it appears to be within guidelines. As previously mentioned, get the parachutes packed in it. You'll notice a difference. When the day comes to sell it, the buyer, may have a larger chest. The chest strap, does not appear too long. As was suggested, cinch it up, to where you like it for jumping, fold it back under and stow with the elastic keeper. Just get it packed-up, jump it and have fun! BTW... nice rig!
Chuck
Do not get your chest strap shortened. Just fold it and put it under the elastic for now. Why? When you start jumping a little higher performance stuff, you'll thank yourself again and again for having a longer chest strap.
