woodpecker
pack volume: smart v/s cricket
If it is an older Cricket - with Dacron lines - it will definitely pack larger than a Smart.
I am not sure if Flight Concepts offers their reserves with - less bulky - Spectra lines.
For example, a rig arrived in my loft with a Dacron-lines (Flight Concepts) Firelite 220 reserve that was s truggle to repack.
After a year of struggling to close that reserve, the owner traded for a Spectra-lined (PISA) Tempo 250 reserve, which was easier to close. The Tempo makes for a tight container, but it is "doable".
Now he is waiting for a Spectra-lined (Aerodyne) Smart 190 which matches the container manufacturer's recommended volume.
Comparing volume numbers form two different lists is worse than a waste of time. It is like comparing apples and oranges.
Finally, only trust volume numbers published by container manufacturers.
Lisa,
Actually the Cricket is probably as strong as the PD.
It is an older design but solid and opens faster than the PD.
It has been is service for a long time and I have never heard of one problem with it, i.e.damage.
In fact, back around 1993, we were drop testing the Racer tandem at the same time that Flight Concepts was drop testing the Mini-Cricket.
After the Mini-Cricket passed it's drop tests, for giggles,we dropped it using the same load and speed that we were using for the tandem.
It stayed together!
The Flight Concepts' reserves do not land as well as the PDR, but I would rate them as a close second or third in the reserve department.
As far as the reinforcement statement, it does not have spanwise tape. It does have reinforcement in other areas that other manufacturers do not use.
In the almost twenty years of production and use, I have never heard of any catastrophic damage during a reserve deployment.
BS,
MEL
Skyworks Parachute Service, LLC
www.Skyworksparachuteservice.com
Rob,
They do install Spectra on them.
I have a J3K that I put a Firelite (176 sq.ft.)into. It was pretty tight with the Dacron and they switched it out for me at a reasonable cost.
It fits perfectly now.
It is an option when ordering a new canopy.
Also the Fury is the 220 sq. ft. model of the reserves.
Cheers,
MEL
