riggerrob 644
QuoteHi kissrg,
I am curious; does the PdeF manual say to put the cable down into the grommet like that? Or should the cable be out of the grommet and around the pin?
It seems to me that with things like in that photo you are creating a harder pull when activated manually.
Good point.
That photo scares me too.
It makes more sense to pack with the ripcord cable ABOVE/OUTSIDE the grommet.
That would vastly reduce ripcord pull forces.
Liemberg 0
QuoteIt makes more sense to pack with the ripcord cable ABOVE/OUTSIDE the grommet.
I had the same feeling, looking at that picture: rather a packing error than something wrong with the design. A quick glance at the pics in the issue of the Atom Legend manual I have here shows that all "ripord loops" are above/outside the grommet...
I think you could make that same mistake with 2 curved pins. I'm sure I can reproduce it on any system with a single curved pin at the end of an RSL lanyard, provided there's enough lenght on the ripcord cable...
The "one-curved-pin-pulling-out-the-other" problem, when you would put them both in the same single cypres-loop seem to make sense for anybody that's ever been wrestling with cypres-loops, packing pins and curved pins. I'll take PdF's word for it that 2 loops solves that problem but when I look at it I can still picture things not working as per design...
But since they tested it and I didn't it must be my all to vivid imagination, though...
"Whoever in discussion adduces authority uses not intellect but memory." - Leonardo da Vinci
A thousand words...
QuoteQuoteHi kissrg,
Good point.
I don't belive that could hapen accidently, I mean I don't think the cable could slip into the grommet after the rig had been closed.
IMO the picture shows a clear rigging error. and one that could be repeated on RW's rsl equipt rigs, but I think you would have to be trying quite hard._________________________________________
Nullius in Verba
