Bill_K
Optima Question
warnings only...
It does the standard 3 warnings plus 3 canopy "setup" beeps and also swoop guide-mode beeps.
It can also store several sets of freefall warnings that you can switch between without having to reprogram it between jumps.
There is no logging feature.
NSCR-2376, SCR-15080
What is the best logger out there?
I've got a ProTrack and a Neptune (I use the Neptune as a visual alti). Both work well, and from my experience (8 years selling skydiving equipment) both manufacturers do an excellent job of taking care of their customers. I don't think you'd be unhappy with either of them.
what is the purpose of having warnings for swooping?
just curious cause I've always felt canopy piloting being a personal judgement call.
Unless you're consistent in your pattern & setup point it's pretty much impossible to be consistent in your swoops.
If you don't appreciate the importance of flying a good pattern, might I suggest picking up a copy of Brian Germain's The Parachute And It's Pilot? He explains it far better than I can.
Like was said, consistency. I also like them since I can spend more time watching canopy traffic and flying to my setup point and less time checking my visual alti.
_Personally_, I do not use a visual altimeter much at all. I always jump with one but rely on my eyes and my dytter more than my Suunto or Alti3.
When setting up for a high performance landing, your pattern is everything. It is extrememly important to be at the correct altitudes in your pattern at the correct times. For instance: I know where in the pattern and my set up that I want to be at 1200 feet, 900 feet and start my turn around 600-700 feet. Yes, this is mostly done with visual judgment, but of course I also use my digital altimeter as well. Having pre-set audible warnings to use as well is just another very helpful tool to have during that set up.
actually I set the Low-Speed warnings (canopy warnings) for my tandem altitudes. Sometimes when you're talking to a student under canopy, or dealing with an "I feel queasy" issue, it's nice to be beeped at and told to concentrate on your set up...:S
Pete Draper,
Just because my life plan is written on the back of a Hooter's Napkin, it's still a life plan.... right?
I understand the patter is everything idea, and I agree. but lets say if your over a different part of the landing area in 3 different areas and the beep is uuh at 350 feet if you listen to the beep you could set yourself up bad there.
edit: oh wait nvm. I get the beep thing now. yeah that would be useful. Thanks for your answers
Na' Cho' Cheese
